Allis Chalmers CA
T-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Mo Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers CA
    Posted: 18 Nov 2020 at 4:09am
There is a 1951 Allis Chalmers CA at a dealership in Missouri.  I'm not familiar with ACs, and definitely not with the CA.  So, I would like to get more specifics on them, i.e. hydraulics, features, opinions, etc.  Thanks.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 4:51am
That most likely will be a "Pin" hitch setup which came out before the standardized snap coupler.
Handy tractors if you have the implements to go with it. Powerful for its size.
Basic hydraulics (IH was way ahead)
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 5:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 5:47am
gee, my '51 CA had Snap-Coupler AND the traction boot gauge on the steering column.
Yeah, I should have kept it.... if only we could go back in time.....sniff,sniff
fun lil beastie, be sure hand clucth works
jay
T-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 6:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 6:57am
last link didn't work, sniff,sniff...
T-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 7:02am
Does this link work?
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 7:02am
70 year old machine. What are you plans for it?
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 7:12am
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 7:25am
It is in Lamar, Mo at Heritage Tractor, what was Purinton's. The tractor looks familiar, I can't remember where I've seen it  though. I would love to have it to put my CA loader on and keep the Woods L306 on my narrow  front CA.
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 7:32am
Just buy it! Help the Orange World!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 7:39am
$2200 is the price, how much was a new CA in 1951?
T-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 8:02am
Go ahead and buy it - I'm sure they will come down from that price.  I'm too much on the fence to pull the trigger, so go ahead and make an offer on it.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 9:53am
There is wide front CA on Craigslist in Halfway, Mo for $900. That is more my price range. I had a Model 160 pull type rotary mower I sold last spring, now I wish I would have kept it. It worked great with a CA, maybe I can buy it back. It may be worth a trip to Lamar to look at this one though! It had good looking rear tires on it and looked to be a solid looking little tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 10:12am
Yep that is the Pin Hitch design.
To use 3-point implements you would need to build or buy an adapter
I like mine but it is a limited use tractor unless you have the implements to go with it.
Charlie
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 10:45am
Looks like I will have to sell some  of my duplicate implements and hope it doesn't sell until I can get down to look at it! I have a snap couple dirt scoop and  an Oxnard rear blade if any one needs them. Also a Bush Hog Model 306 three point rotary mower and  2 Cross Mfg. three point adapters for  a CA, WD or WD45 and a Woods L59 mower for a B, C, or CA. Thanks, Tim  p.s. I know I should post them on classifieds
Edited by rustyorange45 - 18 Nov 2020 at 10:57am
T-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 12:12pm
Here it is running and driving.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 12:55pm
You have first call to buy it, you saw it first. I use my CA to mow my yard and it does a great job and is fuel efficient to boot. Mine has turf tires and a Woods L306 mower under it. I mow the big part of the yard and my wife gets around the house and trees with the zero turn. It doesn't take long to mow. I would like to have a CA with a wide front to put my loader on it. I have 2 sets of wheel weights  and the snap couple hitch I took off my CA when I put the mower on it that I would put on a wide front CA if I had one. They are great little tractors for their size, just a little hard to get on and off of!
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 2:03pm
Check the left rear rim, appears to be a bunch of rust around the valve stem.  Front tires will have to be replaced and it looks like one front rim, can't imagine that screw is in there to keep it from spinning on the rim. LOL   Rear tires look good and that is a big plus, pin hitch is a minus in my world but I'm not looking to buy it.  I paid just a bit more than that for a fresh rebuilt one about 3 years ago, had new fronts but rears weren't as good.  CA's are fun little powerhouses, will surprise you how much power they have for a small tractor.  Check the hand clutch to make sure it works.  Now if you start putting it back to original it's gonna get a little pricey but for everyday use, drawbar equipment it's a great little unit.   Remember the hydraulics are one way, pressure up, gravity down.
T-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2020 at 4:15am
Nah, go for it if you want it.  If it's still there after a while, maybe, but honestly I would rather have a Farmall H or a AC WD.
T-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2020 at 4:35am
If for some reason, it's still for sale in the future, since it's set up for drawbar implements, I have a No. 8 Little Genius 2-12 plow that I believe it can pull.  I would prefer, though, a narrow front tractor.
Orangeisgreat190 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeisgreat190 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2020 at 5:31am
Very strong, powerful, small tractor.  We have two of them and use them for a variety of jobs.  Have 6’ Woods belly on one and rotate attachments on the other.  We have sickle bar, plows, cultivators, and corn planter.  We also have it set up where we can change from snap coupler to a 3 point hitch set up that slides into the snap coupler in a matter of minutes.  The are a very handy little tractor when done this way.
T-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2020 at 6:14am
I hope it's okay to post to CL as, but here are some other possibilities.
