D-17 series 4 and a 6 row cultivator
72AC200 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72AC200 Quote  Post ReplyReply Direct Link To This Post Topic: D-17 series 4 and a 6 row cultivator
    Posted: 11 Nov 2020 at 11:36am
I was wondering if a d17 series 4 can handle a 3-point mounted 6 row cultivator or is that just going to be too heavy? I think the guy I work with said the cultivator was made in the 60s
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 12:13pm
May need frt weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 3:17pm
There was an accessory lift kit available for the D17, it added an extra lift cylinder to each lift arm. You may need that along with all the weight you can pile out front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 5:50pm
Series 4 model has no need for such a kit as they already have two 2.50 inch diameter cylinders.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 8:07pm
I used a D-17IV diesel with four factory front weights for years pulling a 6 row cultivator in dark red kidney beans. I swapped to 14.9 x 38" rears to get more room for the second pass when the rows were getting closed in.  Great combination with no problems. You do need some front weights .
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2020 at 3:58am
my uncle had a 6 row narrow cult on his D17, i don't remember if there were front weights on it or not. the tractor handled it just fine, on both flat and hill ground. (clay soil)
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2020 at 5:19am
You will need front weights--you sure don't want to be using the brakes to steer through your crops.
Keep the front firmly on the ground
Edited by JoeO(CMO) - 12 Nov 2020 at 5:21am
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2020 at 9:33pm
I used to use an Allis 8 row 30" folding cultivator on my series IV D17. I mounted a wheel weight on the front. Used it at least 3 years and it worked great.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2020 at 11:05am
I took the snap hitch from an old 4 row Allis and put it on on a JD RG630 and use it behind a WD45. Have 2 F&H wheel weights mounted on the front. Front is a little light.
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 9:34pm
I have an IH 4 row cultivator I put on mine, lifts it fine, the front does get light so I would think you will definitely need weights but with those added it shouldn’t be a problem.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
