Power steering fluid
Aaron123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Topic: Power steering fluid
    Posted: 10 Nov 2020 at 3:20pm
I have a 1954 WD45 I believe it is factory power steering.. I put power steering fluid in it but I was wondering what fluid every one uses on here?
Can you let me know what works best for you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 5:37pm
I know my D-15II manual said use 5w20...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 7:00pm
besides the thin motor oil, power steering fluid, hydraulic oil, or transmission fluid would all be fine.. If your using TRANS fluid, i would use the older ATF or Type F ... newer types are more addatives.. older types are more like thin hydraulic fluid.
Edited by steve(ill) - 10 Nov 2020 at 7:00pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 9:04pm
Factory power steering was not offered until 1955 .  Yours might be a Charlynn power steering unit, they were common additions to these tractors.  I have heard they actually work better than the factory units though.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 9:25pm
I use mostly fully synthetic 10W 30 in my D14 power steering, works especially well in cold winter temps up here in the north. The extra metal to metal protection in engine oils will give longer life to the pump. In talking to the techs at the steering rebuilding shop ATF is not very supportive of longevity of power steering pumps according to their observations.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 6:56am
The gears in the factory power steering pump are 10 tooth and are almost the same as the engine oil pump gears in the W series tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2020 at 4:28pm
Thank you for all your response
