D10 Series 3 traction booster |
Bronze Level Access
Topic: D10 Series 3 traction boosterPosted: 08 Nov 2020 at 7:56pm |
Any ideas what I can check, it's not working.All linkages are hooked up.
Thanks, Chris |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55316 |
Posted: 08 Nov 2020 at 8:53pm |
Hooked up is one thing. froze up is another. I don't know exactly how they are supposed to work, but on my 10 and 12, there are some linkages under the valve bank, beside the right fender, that when jiggled vigorously, while cursing loudly, seem to have the desired effect of getting them to work...
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 09 Nov 2020 at 5:42am |
The valve body on the load linkage gets stuck. It moves up and down with the load as it senses the position of the linkage. I have had to grab the end of the shaft and move it back and forth to get it to work.
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
Charlie175
Posted: 09 Nov 2020 at 9:11am |
Negate what I said, that was for the series 2
I will have to look at my 3 when I get home to see how that is set up
Charlie
