wiring diagram |
Billy Ray
Joined: 09 Dec 2009 Location: Kinard, Florida Points: 85 |
Topic: wiring diagramPosted: 08 Nov 2020 at 2:45pm |
At one time I had a wiring diagram for an Allis chalmers B with a one wire alternator and a key start ignition and magneto. Somehow I have lost it but I remembered ( or thought I did) that I had gotten it from a member of this forum. If anyone has a wiring diagram for this setup I would appreciate it if you could post it so I can copy it and get my system straightened out. I need all the help I can get when it comes to electricity. Thanks,
Billy Ray
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90965 |
Posted: 08 Nov 2020 at 5:26pm |
well, something like this... You have a separate STOP switch for the mag, not part of the key ?
Billy Ray
Posted: 08 Nov 2020 at 5:44pm |
No, actually the key cuts off the magneto and shuts down the engine.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5282 |
Posted: 08 Nov 2020 at 7:06pm |
use a key switch from an older lawn mower / garden tractor that had magneto ignition.
steve(ill)
Posted: 08 Nov 2020 at 9:34pm |
if you have the key already, thats great... If not, you need a key switch that has TWO TERMINALS connected when in the OFF position... those two terminals go to the mag and GROUND... You dont use the ON position, ( unless you have headlights ) just the START position for the starter motor.
steve(ill)
Posted: 08 Nov 2020 at 9:47pm |
here is a Briggs lawn mower switch.. at the bottom left of the page it says terminals 1 + 3 are connected when OFF... So those would be the 3=MAG and 1=GROUND... It says 4 + 5 are connected in START, but 4 is not connected when you go back to the RUN position... so 5= POWER (12 v) and 4= Solenoid wire .
![]() Edited by steve(ill) - 08 Nov 2020 at 9:54pm |
Billy Ray
Posted: 10 Nov 2020 at 8:33pm |
Thanks a lot for the info and the help. I appreciate this bunch of guys on here.
