A.C. I60 adjusting valves
Dieselherb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dieselherb Quote  Post ReplyReply Direct Link To This Post Topic: A.C. I60 adjusting valves
    Posted: 07 Nov 2020 at 6:43pm
I'm trying to adjust the valve clearances in the 2.9 diesel engine.There are marks for timing injection pump but I can't find TDC marks
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:57pm
When both rockers are moving on a cylinder adj the valves on the companion cyl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dieselherb Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 7:16am
this is a rebuilt head so not near original setting. can't find TDC only setting from injection pump. Which I think is 22 degress BTDC. I tried adjusting 1235 then turn crank 180 degrees adjust 4678 but 5 was loose enough to fall away from pushrod. then tried 360 degrees then 2 others were loose. Really at a lose!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 10:19am
Ideally you do each cyl on tdc...both valves closed and "loose". You got to be smart enough to know how to get there.
This page was generated in 1.357 seconds.
