Wheel Wrenches needed
elbyCJett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elbyCJett Quote  Post ReplyReply Direct Link To This Post Topic: Wheel Wrenches needed
    Posted: 07 Nov 2020 at 1:15pm
I have three tractors (2 CA's and a 160) with spinout or power adjust rear wheels.  I do not have the special wrench that is used to unlock the excentrics on them.  Does anyone have the wrench.  The excentrics have a 13 mm square head.
D-14, 160, 2 - CAs, 2 - Bs, 2 Gs Roto-Baler, 82S Mower, Rake,444 baler, Kentucky
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 1:43pm
Use two 3/4 inch sockets, smaller one inside the other weld them together, works like a charm
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 3:52pm
I use a Craftsman 1/2 inch 8-point socket (1/2 inch drive, usually need a cheater bar on the socket handle).
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 6:45pm
I just used a regular socket.  I don't remember what size, but it fit just fine and did the job.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 5:28am
A new CA from the factory had 3 eccentrics and one fixed bracket on each rear wheel.
The eccentrics had a 1/2" square protruding head.
A 1/2" drive extension will fit.
Be carefull if the eccentrics are seized, the head will twist off fairly easily
G
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 7:10am
If one of y'all sends me their phone number ( I can't figure out how to post pictures) I'll send you a picture of the two sockets welded for the eccentrics. I'll recheck it to be sure its 3/4 or 1/2 .
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 7:21am
I guess this would help,314-791-0276
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 10:36am
weld two together back to back as above...or just tape two together..
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 3:32pm
There are two types of heads on the eccentrics.  The CA/D10/D12 where usually 1/2 inch square while the WD was generally a 3/4 inch hex head.  I think the two types are interchangeable.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 6:44pm
Weld them together ,I took one smaller socket and put it inside a larger one then welded them together with the 1/2 inch female end out on both,put one on the eccentric and use a breaker bar on the other,
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 8:31am
I believe the 160 is a metric size, however I have been able to use a 1/2" eight point socket on mine.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 9:18pm
I had an impact socket to fit those I kept on my tire service truck. But I am getting old and cannot remember where I got it. Probably from one of several wholesale places that sell just to tire shops.
