Surplus Record . Com |
HD6GTOM
Topic: Surplus Record . ComPosted: 07 Nov 2020 at 12:16pm |
Guys I found this site while looking for forklift info. I entered Allis Chalmers. They have something called Ball Mill and Sag Mill. I have no idea what they are. But it says they have 3000 HP? Dont tell Shameless, he'll have one of those dang 3000 HP motors on his dang old machine, world global warming will be over. Heck he'll have the equator covered in 6' of snow.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90808 |
Thanks(1)
Posted: 07 Nov 2020 at 12:48pm |
everyone has heard of a grain mill where you grind grain... A ball mill is a TYPE of mill used to grind coal at a power plant.. You have a BIG BOWL like a soup bowl but 6 - 10 ft in diameter. You put in a dozen "balls" that look like steel bowling balls... You rotate the bowl with a motor and the balls roll around inside.. You dump crushed coal into the bowl that is 1-2-3 inches in diameter.. The balls crush the coal into powder. This all happens inside a box with a blower fan on top causing a vacuum.. The "coal dust" gets sucked out the top as more coal is added to the bowl.. Constant feed and extraction.. You can run several tons per hour thru them..
Edited by steve(ill) - 07 Nov 2020 at 12:49pm |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 07 Nov 2020 at 1:10pm |
Had mills as that at the Power Company dirt burners, actually used Barrels of misc diameter steel balls all rolling in the coal to beat it into powder, that would be air blown thru ducting into the furnaces.
steve(ill)
Posted: 07 Nov 2020 at 1:13pm |
and a SAG mill is a SUPER SIZED Ball mill... Big as a 3-4-5 bay garage... Grind a variety of WHAT EVER...
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 07 Nov 2020 at 4:58pm |
They also used ball mills to grind precious metal ore. The balls could be as big as a grape fruit and small as a quarter. I hauled them out of KC to south Mo for the mines down there. The large ones were heavy as the dickens. Leon
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 07 Nov 2020 at 5:38pm |
[TUBE]NulDDkljI7o[/TUBE]
shameless dude
Posted: 07 Nov 2020 at 8:39pm |
you spose i could plug one of them into an RV outlet?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 07 Nov 2020 at 8:41pm |
ball mill
[TUBE]aVQ9B3LtCPk[/TUBE]
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 07 Nov 2020 at 9:23pm |
So, then I take it the coal dust is highly flammable?
steve(ill)
Posted: 07 Nov 2020 at 10:23pm |
YES... a "coal mill" is a little different than the above movies.. The coal is ground into a very fine powder. The atmosphere inside the mill has to be maintained so it is out of the Explosive range.. There is a big exhauster fan that SUCKS the dust out of the mill and forces it thru tubes into the blast furnace ............ at a power plant....... Everything is normally computer controlled these days.. Cuts down on the explosions.
Coke-in-MN
Posted: 08 Nov 2020 at 10:27am |
The coal dust is blown into boiler and the amount controls the heat output of steam to run turbine for generation . The result is also no buildup of unburned coal and just a coal s-lag is the result along with fly ash which is saved to use as a additive to cement in making concrete. (posalone)
the s-lag is separated and graded as roofing shingle particles and as blasting materials for sand blasting media . Edited by Coke-in-MN - 08 Nov 2020 at 10:30am |
