WD45 used Power steering system
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Topic: WD45 used Power steering system
    Posted: 06 Nov 2020 at 6:24pm
Have a PS system for a WD45 Do not have the hood.  Steering motor is all there, but partially disassembled.  Have the double pulley, pump, idler bracket, tank and all the brackets.  $400.00 for everything.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 6:38am
Can you email pictures? lselkriver@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:12pm
The PS system has been sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 3:52pm
Dang it Lon, just cause I'm not able to get on here all the time like you, doesn't mean you get to come over here to WI and steal all the stuff I'm looking for.  LOL
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 7:09pm
Guys, Dave traded the power steering unit to me against that nice WD45 I had for sale. Lon, I'll try to get some pictures sent your way between repairs here if you are still interested.
This is not quite a bolt on and go setup. Will need some work to become operational.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 6:19am
I am interested in the power steering Alex. If you could email pictures that would be good. Ted why didn't you grab that WD45 in your back yard a month ago. It had the power steering. I was tempted to get it but my shed is full. My rule is, if I can't get it into the shed it doesn't come home.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2020 at 11:22pm
I also have an unit but no pump parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 2:05pm
Lon, you never let me know about the 45 w/steering?  I never saw it.
Your shed is NOT full,,,,,,,it's packed and stacked!
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 2:21pm
I apologize if this question is ignorant as I am unfamiliar with the WD45 ps setup.
Does the WD45 ps setup make for an "easy" ps swap for the smaller B, C, IB, or CA?
Versus 1978 Dodge 1/2 ton 4x4 Saginaw push-pull ps box.
Edited by KMAG - 13 Nov 2020 at 2:23pm
This page was generated in 0.273 seconds.
