Local Tractor Pull
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Local Tractor Pull
    Posted: 01 Sep 2010 at 4:47pm
I stay out of the big classes for a reason.
This was the 8000 lb STOCK class
[TUBE]I1KHk5lHmTs[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 4:49pm
[TUBE]CMsHMS3sgcw[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 4:50pm
[TUBE]lWBARrWUSJk[/TUBE]
Charlie
[TUBE]rGi7HWOsnJ8[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 4:52pm
[TUBE]rkxiVzURQyE[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 4:54pm
[TUBE]dDrTLT_2vBg[/TUBE]
[TUBE]C0IUie1Wq2A[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:01pm
How is that Ford in the first video even remotely considered STOCK?
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:19pm
Forrester's Farm Equipment?   Chambersburg, Pa?   Those fellows know how to make a FORD   First On Race Day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:22pm
That is the Page valley Fair in Luray VA.
There is a strong Ford presence here with several tractors like that. The 12 and 15,000 lbs classes had 17 tractors, mostly Fords.
At the Fair, it's pretty mush bring anything that will pull, I laugh at "stock".
Charlie
Jason(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:23pm
I think you would use the term "stock" loosely with that 9000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:33pm
HA! HA! HA! HA! I can't stop laughing at that poor Deere. He should have just stayed home.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:43pm
(yeah, what he said!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:43pm
Charlie, our county fair's "stock" pull is the same way. The classes were so full of "innovators" that the fair board created open classes for "slightly modified" :) tractors and guys from outside the county to run in it. We had guys running 190XT Diesels in the 6,000 lb class with inline injection pumps, Oliver 880 Diesels with 1800 engines in them so they could run turbos, 88 running on alcohol, and on & on.
In order to run in the stock classes, you must have correct engine for year and make of tractor (or factory replacement) ie; a D262 engine can be put into a WD-45D and still be considered stock (thats how those guys get away with running 1800 engines in 880 diesels), the tractor must run regular tractor fuel (gas, diesel, or LP), must have a working PTO, and must have factory seat.
My dad is actually considering putting a D19 diesel engine in a WD-45D chassis and taking it to some pulls to see how it does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:50pm
These are all stock! I swear LOL!
[TUBE]q5aQCAZUd14[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 7:23pm
(G) Yeah, that's just special "Exterior Trim Package" offered for a very short time...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 7:34pm
The guy puttin my WC back together has a MinnieMo UB that dyno's 150HP at stock rpm's. It looks all stock but I've seen the grinding done to the inside of the block and the notches cut in the cam to let the rods go by and the 3 pound coffee cans he calls cylinder sleeves that carry the Alison pistons. He runs propane at or very near stock compression ratio too. All it takes is CUBIC INCHES.
Jeff(WC)(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 9:06pm
at 2 minutes and 30 seconds listen to the announcer of the Cat Daddy...never heard those tractor models called "D dash 21"
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 12:44pm
Was this a stock class or a "farm stock" class?  Big difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 2:49pm
Farm stock
Charlie
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 7:40am
farm class looks like a lot of fun. Last pull we where at guy where driving thier tractors in from home.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
This page was generated in 6.004 seconds.
