cultivator blight |
Post Reply |
Dean(IA)
Silver Level Joined: 12 Sep 2009 Location: NE Iowa Points: 426 |
Posted: 31 Oct 2020 at 9:18pm |
I had never heard the term, 'cultivator blight" which referred to plowing out hills of corn, until the last few years. Cultivating corn cross ways after it had been planted with a check wire was pretty apt to result in cultivator blight. On an earlier thread, plowing corn (cultivating) was discussed. In Fayette County, Iowa , when I was young, we called it plowing corn. Must be a midwest thing.
Dean(IA)
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8160 |
That or "iron worm"...cross cultivating checked corn shouldn't be a problem...dad never said anything negative about it. It was known as "plowing" here too.
Edited by SteveM C/IL - 31 Oct 2020 at 11:45pm |
Herb(GA)
Orange Level Access Joined: 15 Sep 2009 Location: United States Points: 1020 |
My opinion is both of you are correct; in hillier ground (neIA) pull type cultivators will slide downhill several inches resulting in uprooting of corn or other row crop; does not occur in flatter grounds (Shelbyville, IL). Cultivator was the implement name in central KS. Our two row horse drawn cultivator was horse drawn; Dad converted it to tractor drawn. The operator siting behind the cultivator pushed on foot pedals to turn the two large cultivator wheels a few inches to the left or right. In central KS an implement with many disc blades was called a disc. Here in nGA such implement is called a harrow or disc harrow. Herb(GA)
tomNE
Orange Level Joined: 13 Sep 2009 Location: dorchester, ne Points: 1225 |
We now call them topsoil eliminators!
But in the early days, not many options besides them, excisted!
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9190 |
WE used a Spike Harrow to break up hard crust ground just as corn was coming up .
Orange Blood
Orange Level Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
In my family (Central Nebraska) cultivator blight is an operator error, not a gravity issue
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
HD6GTOM
Orange Level Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
In southern IA we plowed corn too. My grandpa from northern IA always called it cultivating corn. He retired from farming and always came down to help plant and cultivate.
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3320 |
Interesting. Central IL “old terms” (1960-1980s)
“Row cultivating” was our term used to describe corn or soybean seedling rows being cultivated. You’d consider it good to do 1 pass thru corn & 2 passes thru soybeans. Problem fields like weedy soybeans would also get walked to cut out weeds with a weed hook or hand pull weeds. ”Field cultivating” was our term for field tillage before planting crops. Edited by AC7060IL - 04 Nov 2020 at 6:59am |
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11544 |
We cultivated corn up through the 80's. My Grandpa used to come up and stay a few weeks in the summer and he did most of it. Had JD 40 and mounted 2 row cultivator.
When he got too old to do it anymore, Dad bought a 3 pt. 4 row unit. I remember my first time cultivating at about age 14, dad never showed me a thing, just said you lower it to the ground and go and watch what you're doing, pretty straight forward. OK. So off I go, did good, then I'd be pulling out corn, and I'd adjust, and then be OK, then pulling out corn, I'd go up and adjust, had a heck of a time. What really had me puzzled was Dad had said everything should be good to go adjustment wise. He came home from work and I was up at the shop adjusting again, obviously more than a little frustrated. He probably saw all the dug up corn on the way home from work too, probably not real happy! That's when I learned that the outside shovel goes back down the same row when you turn around!!! Oops. Edited by Tbone95 - 04 Nov 2020 at 9:11am |
Brian F(IL)
Orange Level Access Joined: 14 Sep 2009 Location: Paxton, IL Points: 2698 |
Same terminology where I grew up...
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2876 |
Since a tike it’s been cultivating corn never heard the term plowing corn till year or so ago on Agtalk.
If I’m cultivating anything someone better be paying me a premium. Cultivated green beans and sunflowers. We no till a chunk of our corn so it’s not feasible. Besides to much root pruning and stirring it again just germinates more weed seed.
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
i always told dad that lightening must have struck there!
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4520 |
My job in my early teens was cultivating (called scuffling in Canada) corn with a mid mount two row on a D 14. Blight was common when I couldn't keep my eyes open.
Years later I started growing dark red kidney beans which required building a hill on the row so the plant could be knife cut (pulled) at harvest. Usually took two passes. My machine was a D-19 with a 6 row rear mount. Worked well but had to install 14.9 x 38" rears for the second pass. A D-17 IV diesel arrived and now I used half as much fuel. The problem was that on a D-17 the front wheel spacing was either 58" or 62" which was a problem when the planter wheels were spaced 60". The solution was D-19 front wheels or finally wheels from a Gleaner A both with a different offset to get 60". Eliminated a lot of cultivator blight! Rears were changed to 14.9 x 38". Gets a little boring after 250 acres with two passes per year but we were usually well paid at harvest.
Post Reply | |
