Did you see Otto Kilcher |
john(MI)
Topic: Did you see Otto KilcherPosted: 28 Oct 2020 at 11:17pm |
Bleed the diesel fuel system on his portable welder? He filled up the tank. Then he put some sort of fabric on the fuel fill hole and blew in it. After a couple times, he tried and it started right up. Funniest thing I'd ever seen any of them do. Well, maybe Jane getting hit in the eye by the rifle scope the first time shooting a rifle.
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 29 Oct 2020 at 6:31am |
Had a 76 Dodge dually with a 383 in it and if you let it sit and idol for more than a minute or two when it was over a 100 degrees it would vapor lock. Would end up blowing in tank through fill hole as much pressure as possible then quickly put hand over whole then reach in with other hand and crank engine. Would always start right up, then jump in and take off down the road with it held to the floor until it cleared up. Desperate situations call for desperate measures, sure glad nobody with a camera was around to record it.
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 29 Oct 2020 at 6:47am |
Done it many times wrenching on old vehicles. Stick a blow gun in the tank. Wad up a rag, and put it over the hole to help keep the air from coming back out. Give it a good blast of air. Helps prime the fuel pump and carb.
Edited by truckerfarmer - 29 Oct 2020 at 6:47am |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90825 |
Posted: 30 Oct 2020 at 9:04pm |
YEP... just dont use TOO MUCH AIR...
also do this with 55 gallon drum of gear lube... put a 3/4 inch valve on the small port and lay on its side... if it is COLD and drain slow, put a blow gun in the BIG HOLE and put a couple small blasts in ( 3-4 psi) to make it come out faster !!
truckerfarmer
Posted: 30 Oct 2020 at 9:31pm |
I use the same method to drain water heaters.
