Need 3 HD5/6 Track Links
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Topic: Need 3 HD5/6 Track Links
    Posted: 01 Sep 2010 at 8:40am
I found a good used track in the boneyard up at my ranch but is 3 links short. Anyone have 3 good links with P/N 078835, 078836?
The P/N on the worn out track on my machine is 051845 and 051846
Looks like the only difference between the different P/N's is that the  078835, 075836 has much stronger webbing between the rails less likely to break.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 4:18am
i may have a few after thinking about it. i will be to my storage yard this weekend i will check. do you need the pin and bushing? the part number was just for the links.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 5:47am
Sounds like he is making 5B track into 5G length or? believe he needs it all
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 8:17am
I need 3 complete links with pins and bushings. The track I found only had 30 links, I need 33 on my dozer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 12:25pm
http://www.northernengine.com/
They have a place in Gelette WY
 May try Thill Track and Tractor in Eau Claire WI also .
You could add in those three links using 2 master pins and bushings in track
dyno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dyno Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 9:49pm
Thanks Coke...yeah, I plan to add the missing three links just like you said.
Will check out the sources you ref'd.
Thanks,
dyno
This page was generated in 1.684 seconds.
