Allis B PTO Delete
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Topic: Allis B PTO Delete
    Posted: 27 Oct 2020 at 9:25am
I have been debating this project for a while.  To remove or keep my PTO.  I always thought the B's with the rear end cover plate was a different feature you don't see too often.  Since I don't have any powered implements to go with this tractor I decided it's time.
The unsuspecting victim.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 9:27am
The seat and seat frame removed.  Draining the transmission fluid.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 9:29am
The PTO unbolted.  A couple of taps with a mallet and the seal was broken.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 9:34am
The PTO is off.  I was amazed at how easy it was to remove.  Slid right off.  Thanks to those who provided info on how much a PTO weighs.  It was heavy but easily handled by me.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 9:37am
FYI.  I'm keeping the PTO.  It will stay with tractor in case I want to put it back on.  There was nothing wrong with it and it does work well.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 9:41am
Everything inside looks great!  Not bad for a 70 year old.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 9:42am
All cleaned up and ready for the cover plate.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 9:48am
Cover plate installed.  Filled the transmission with new fluid.  No leaks yet.  Wink  I just need to bolt the seat frame back on the tractor.  I don't think the cover plate makes the tractor more useful, but it does clean up the rear end.
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 12:07pm
I can tell you put a lot of thought into what you do BEK.  Cookie sheets on the floor, asking about the weight AHEAD of time, how clean that tractor is, inside and out...  Well done!
Ben
Leave things better than you found them.
1941 Model C (restored 2020)
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 4:26pm
BEK,  You have a very unique B.  I can't remember any without the PTO.
You know, that was how they came from the factory.  The PTO's were installed in the field.  They were heavy and awkward to install but there was a method to it.  You got a lift and a swing so that it went on the top stud.  Then you moved it into place.  Secret was to get the shifter square on the drive gear properly.
We  sure put enough of them on.
Nice Looking B.   Thanks for taking such good care of my favorite.
Good Luck!
Bill Long
ps:  I do remember seeing a CA - I think - with a delete plate.  I talked with the owner and since he was pulling with it he did not want power to be drawn off by the PTO and the hydraulic.
Edited by Bill Long - 27 Oct 2020 at 4:29pm
fleeter allis fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2020 at 9:56pm
My B did not have a PTO and belt pulley assembly until recently I think when one was installed by the previous owner. When I bought the tractor from him, he included the cover plate. I have it in the shop.
I'm a man...and I can change...if I have to... I guess.
'44 B, '46 WF, '49 G, 810GT, 916H, 620
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2020 at 6:29am
Not many Bs with the large PTO shaft.
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2020 at 8:21am
I thought the same thing - that larger PTO is a nice feature to have when you're using the PTO feature of the B or C.  Not that there aren't adaptors, but it just simplifies things.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2020 at 9:11am
Thanks for all of your input guys.  It was a fun little project I thought I'd share.
