520 flex head AHHC troubles |
Post Reply ![]() |
automaticdave ![]() Silver Level ![]() ![]() Joined: 20 Jan 2011 Location: Granton, ON Points: 256 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Oct 2020 at 12:30pm |
The lever (with the two set screws) that the switch turnbuckle connects to slips or turns or moves forward on the rock shaft, I tighten the setscrews as tight as possible but it won't stay put. I replaced the left outer-upper stabilizer arm retaining pin but no dice, what am I missing on this thing? Thanks Dave
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21915 |
Start by raising the header clear up and set the safety stop. Pull down on the cutterbar at all linkage locations and make sure the cutterbar is actually DOWN all the way max. Use Gr8 bolts on that arm and get them TIGHT after positioning it where it needs to be. Now weld the arm to the shaft on the end. Now adjust all sensing arms so they all touch the linkage arms all at the same time. After all this, you make have to tweak the adjustable linkage going to the plastic signal arm on the end.
Thanks Doc, I wanted to weld it but I wasn't sure if I should before I asked, I will set it up correctly & do it. Thanks again Dave
Post Reply ![]() |
