D17 Power Steering Fluid
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: D17 Power Steering Fluid
    Posted: 22 Oct 2020 at 7:35pm
Finally hoping to get the old girl started after a longer than ever expected paint job. The manual says use automatic transmission fluid in the system. Is that still the fluid of choice nowadays with all these universal oils? Thanks in advance. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2020 at 7:41pm
Universal hyd/trans fluid. Steering will work better and leak less.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2020 at 7:47pm
Thanks Dr.!! I will put some in the front bolster and hopefully fire her up. Hopefully the system will clear the air out of the lines easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2020 at 8:00pm
Approx 5 quarts. Just over the gear inside 1/2".
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2020 at 8:13pm
If the leaks are fixed, ATF works well.  Especially in colder weather.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2020 at 7:53am
I found this to be true as well........hydraulic fluid is a little slow in real cold weather and tends to "pump out" of the breather until it gets warmed up a bit.
D14JIM14 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2020 at 9:18am
I had a series 2 17 and had trouble with foaming out of the breather plug . As some one on here said be sure the hydraulic fluid is anti foaming . I dropped the oil I was using and got universal hydraulic from NAPA that was anti foaming and problem cured . Ran it blading snow in winter and was not stiff when cold .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2020 at 3:23pm
I followed the Dr’s advice and used the universal Hy-Tran in my early D17D. I can’t really speak to the cold weather function since it parks in a heated shop.
If you’re getting foam out of the breather you have a leak on the suction side of the pump between the reservoir.
