is tired of being embarassed.....
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: is tired of being embarassed.....
    Posted: 31 Aug 2010 at 9:54pm
so I've pulled with the WC a few times and have to say Im disgusted....Farmalls and JD's running ALL over me....the governor wont let it open up(I could honestly bypass it and not hurt it for the pulls I think), and it just doesnt have enough guts....what to do? I have a 45 parts engine here I can part out to stroke mine but is it worth it? Ideas? Or should I just start with something bigger?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 9:57pm
And that's how it starts! LOL
Benny, just funnin with you. But, seriously, that's how it starts
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 10:00pm
the worst part is Im one of about 4 people in a tri county area that runs AC.....Olivers are more popular around here!
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 10:17pm
just from my experience of watching, not doing, Olivers do seem hard to beat. lot of red around here, though.
On the other hand, AC can be quite competitive, hang in there.
My first thought, if you are held to a max RPM, start working with your governor/carb, until you can get the max RPM under load. But, I'm speaking from my general knowledge , limited as it may be, not my experience of pulling, of which I have none
Hopefully, some of the experienced 300 foot warriors will give you better advice
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 10:18pm
there isnt much of a max RPM rule around these parts...you should hear some of these things scream
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
JNunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JNunn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 5:40am
I know what your going through..my 36 WC pulls like a champ in 3500 and 4000. However my wd45 just cant get the job done...Im gonna start playing with different gov. springs and shaving the weights.
WC, WD, WD45, WD45D, WD45PS, D17, B12, Two-Ten, 185, 710, and 7010
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 5:52am
how about an RC rear end set
1968 D15D,1962 D19D
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:25am
You are pulling against more than stock tractors with what sounds like a pretty much stock WC. First, is your governor synchronized with the carb? They act doggy if they aren't. Second, I'd put in the 45 crank and carb using your WC pistons. That's the fastest and cheapest first step to making your WC competitive.
Wink
I am a Russian Bot
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:32am
How much money do you want to spend?
175 gas cam shaft, D17 IV propane head, 175 gas carb,  biggest set of overbore pistons you can get(not sure if Sealed Power still is furnishing old M & W kits or not).
Seriously with enough desire you can get a WC up to 100 HP.  A Farmall M is an easy 100+, a John Deere A, can be pushed to 100 if you can hold the crank togeather, a center main would help.  Oliver 77's  just getting warmed up nicely at 100 HP.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:38am
IT is a Money and Pride GAME !!!!
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 9:05am
Well can I say go Oliver? I'd rather see an Oliver beat an AC than any other color!  I've always liked Olivers. Had 3 on the farm and really enjoyed running them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 9:31am
I too like Oliver but they are only second to AC. I heard that the reason the Olivers were so popular was due to buick engine that would bolt up with no modifications. Each year we go to the Super Pull in Richmond there is about 50 Olivers and all of them can pull it out the door. But there are also about 6 or 7 styled WC's and even though they are smaller in size alot of them probably have the Gleaner E engine in them. That allows everyone of them to pull it until they about hit the wall.
Money plays a big part in it but my uncle's 530 Case is all stock except for a airfilter and it burns aviation fuel. A person with a $12,000 engine in a Farmall M only beat him by 5 feet. Due to that he sold the Farmall and now has a Minneapolis Moline that the motor is as long as it is.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 11:15am
Lou beat me to the punch on that one!
Your just going to have to live with Olivers walking all over you for now. They always have the best power/weight ratio. Theres a guy around here who has olivers. I am always beat by is 66. He has the front end ground down and has the thing with all weights off stripped down to 2300. Save up some serious money. Build an engine. Take off anything you don't need for pulling (which means if it's not the engine, transmission, draw bar, seat, or gas tank, it can probably go). Switch out your gears. What most people don't realize is tires are a HUGE deal in pulling. Tires with about 50% tread will do far better then tires that are brand new. Tires with lots of roadwear are good too, if your club does not permit you to cut your tires. It's also all about momentum. Just by turning the screw on the carb or putting a different spring on it alone isn't going to make your pull incredibly better. It's all about the combination. Weight placement depending on track conditions can even make a difference. Your not going to be able to beat the people you are discribing at next weeks pull. Try talking to them. Maybe they will let stuff slip. Don't count on them though. At least ask them how long they have been pulling. I've learned a lot the past 2 years just by talking to friends at the track and some day that information is going to come in useful when I really feel like spending the money to build a puller.
It's exactly how Fred described it. It's all about Money and Pride.
Edited by morton(pa) - 01 Sep 2010 at 11:19am
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 11:51am
So for Old Allis Pullers, what can be done to help them out without dropping a load of cash?
B?
C?
CA?
WC?
WD/WD45?
I run against Oliver 60's (which I normally beat) but get whipped by 8/9N, Farmall B's in the 2500 lb class.
Charlie
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 12:45pm
B?
C?
CA?
WC?
WD/WD45?
NOTHING !!!! Most pulling tractors have a different engine than what came in them stock even if it is stock. such as oliver 77s with 310 or 320 wakeshaus wc with combine engines c and h farmalls have combine engines. then they are the ones like myself with combine engines and 10000 dollars worth of parts and cubic inches. ps the fords have 192 cubic inch engines in place of the 172 and the 8 and 9ns have funk conversions.
Edited by mlpankey - 01 Sep 2010 at 12:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 12:56pm
ps you can hide a 75 shot sneaky pete nitrous system on her for about 200 bucks but you will evently have the cost of a rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 3:40pm
Nitrous is lazy....not a bad idea but I wont use it. I've thought the idea of an Oliver, but I'll stick to my guns and still run AC....found a D15D for 2000k or best offer and a D17D for 1200 obo....still checking pics, condition etc....I'd prefer to go diesel, and I think it would be easier to get power out of them....are they? whats the dry weight of these 2 types of tractors? I still want to pull in the 4500 and up classes but could always pull the WC in 4500 and a D series from there up.....
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 5:43pm
Actually it is easier to get power out of a gasoline engine.   Bump compression and run av-gas.   Photo attached is Killer's last run.
We got "dynoed". some people have no sense of humor at all. Local track has a 15% over rule,   Neb on a Super 77 is 42.3 hp,  only "showed" 115 and some change.  High compression gasoline engine.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:57pm
 Benny, to be a successful puller takes a lot of careful planning. Tractor color don't mean a thing.  It's the pilot and the machine and the track. The machine can be the most important, but not if another pilot can stay out of the minefield left by previous pullers and you can't. Or you don't get the balance right to keep the front end down and the drawbar up, likewise the tire  size, pressure needs to match the track , and the power you have.   A lot of good info has  been shared here  but remember you crawled before you walked and you more than likely fell a lot learning to walk.  My advice to you is fine tune that WC, get her running like it should, put her on a diet, pull at 3,000 and 3500 in a 3  or 3.5 mph class, your out of your league in 4500 with out a fresh engine with a few light inexpensive mods. Get the basics down  pat, first, then determine what you need to do to improve, whether its more seat time, more traction , or more power. I started with a WD45 and it took a few years to start winning. My  D17 I pull now is still yet to win at the home track, but it will , and the rules will change and it starts all over again.   I don't have the money to throw at more power and it wouldn't help me anyway.  I pulled once last year ,at our fair , took 2nd out of 28 in 4500 , I went down the right side of the track , Ollie 88 went down the left side ..beat me by inch's.  Don't give up, get smart and you'll get luckier.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 7:33pm
B?
C?
CA?
WC?
WD/WD45?
OK, got it figured out. The thing to do is, right after you win, load up and head towards home - follow & hope like heckum that tractor rolls off your trailer onto mine.
smuggler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 8:43pm
get some menthonal lol.. Its cheaper than gas
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 9:32pm
Get your drawbar as short and as high as you can get it. Watch the different sleds, some favor tractors with larger wheels than ALLIS, some favor with longer chains or cables gives the Allis a chance.
joshjohndeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 10:05pm
well benny if u really wanna pull with an older tractor get a d-17 diesel and run a d-19 head and cam with the turbo assy , then u can pour the fuel to it and file the governor weights oh and also dont forget remove the dowel pin from the flywwheel and tapp it and add another bolt, this will help hold it together when u add a heavy duty buton clutch ( trust me u will be slipping the clutch to spool that turbo if u go to a high gear setup)  u will have the advantage of a 2 speed hi and lo, and also be able to gut it down to a lighter weight.  i would add a support in the center casting for the clutch shaft also.  sorry if i got carried away but have thought about building one myself.  hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 7:07am
soo many choices. I think Im going to just hunt for a D17 and build from there....though Im open to dropping a Gleaner E in the WC if anyone just has one they are tired of walkin around lol
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 7:34am
my dad had a wd he pulled with it  he was getn bet some but then he buillt it with help from a spare gleaner e moter  he had worked on the govs and put a diffrent manafold on it he said winning was easy after that lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 9:25am
  gas will make more power than methanol on a 226 engine because the cross section of the intake runner is not large enough for the double amount of methanol that it takes to make twenty percent more power than the btus of gas.   However you can increase the compression ratio alot more on the cheaper methanol and generate more bottom end torque but you want see it as a  increase in overall horsepower just by a fuel change alone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 12:51pm
Josh, have you ever done the build you're talking about? Just curious. To run a D19 head going to need a later block with the water pump on the block. Early engines has the pump on the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 10:25pm
brian
no i have not done it myself but about 12 years ago my grandfather did the setup on one for an old boy from alta vista, ks.  that thing screamed when grandpa got done.  the only flaw was apparently the crank wasnt strong enough because when the guy was spooling the turbo at about the 10th hook on the tractor she came undone at just under 2200 rpm, but when it was still together he either won or placed second in all his hooks,  grandpa told me that one of the pulls he was at he was competeing against 4055 and 4320 john deeres along with sum 1256 and 1066 IH'S.  Im not sure if it was true but grandpa told me that and said he placed second at that pull.
Shane H. (Mi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shane H. (Mi) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2010 at 7:07am
Anyone can compete with a "stock" tractor, the devil is  in the details my friend! Drop a class and get into the 3500# class and dominate.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2010 at 7:55am
I trophied a lot with a bone stock D17. I picked and chose my tracks though and it's been 10 years almost since I pulled last. Pulled in both farm stock and classic. In classic back in early and mid 90's and then a farm stock class appeared in late 90's. When pulling in the classic where the other were mostly hopped up I was still competitive and trophied often. That was when there used to be 25 to 35 tractors in each weight class (6,500# & 7,500#). Then the farm stock started up and they were pretty strict with the rules and I dominated those weight classes on my tracks (black dirt or clay and sticky). Now the farm stock is no different than classic in my area except they supposedly make you keep your stock drawbar. Which isn't true cause some guys drill an extra hole to slide the drawbar shorter. I quit the game cause it was more about money and what you could hide than about what you and your tractor could do out of the box stock. I have a family to support and don't play the money game. If you really want to have fun take the stock tractor and hook up with a local field day club where you can do a little plowing or tillage and get to know your neighbors. For me it's much more enjoyable and a lot less hectic. But to each his own. I just don't have time for the dishonesty associated with tractor pulling anymore. Good luck in what ever you do.
Wink
I am a Russian Bot
This page was generated in 0.238 seconds.
