Forum Home Forum Home > Allis Chalmers > Shows and Events
CA wide front end
DanC(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC(WI) Quote  Post ReplyReply Direct Link To This Post Topic: CA wide front end
    Posted: 17 Oct 2020 at 9:54am
Lookng for right side spindle for Allis CA wide front end. Looking from drivers seat.
Edited by DanC(WI) - 17 Oct 2020 at 9:56am
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2020 at 12:39pm
Is it broken? If not it can be built up and turned back down. Or if you are handy with your hands, build it up yourself with 7018 rods and with a small hand grinder get it close and finish with a file and sandpaper. You'll be proud of it. Then if you really want to finish it off get Mylar bushings from a truck application and you will be shocked at how easy it steers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2020 at 9:18pm
No, it's not the same as the left one, it's longer and looks different. Found another front end in good condition.
This page was generated in 0.235 seconds.
