Time to lite them up !!!! |
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Topic: Time to lite them up !!!!Posted: 16 Oct 2020 at 7:01pm |
Just lit it up this evening , heats ,Business Shop , showroom and my house . All 24/7 |
DougG
Posted: 16 Oct 2020 at 7:09pm |
Great looking setup,, luv those outdoor wood burners
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34631 |
Posted: 16 Oct 2020 at 7:32pm |
Yup, lit mine two days ago, glad I did. snowed here this morning... but was gone 1/2 hour after it quit.... but you know it ain't gitten any better till spring rolls back around again...
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 16 Oct 2020 at 7:49pm |
Gosh, I just may have to give some thought to turning off the a/c here? Nah, I will just lay down till that thought goes away.
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Posted: 16 Oct 2020 at 7:58pm |
Starting my Hardy Heater tomorrow. Going to be cold here for awhile!
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 16 Oct 2020 at 8:24pm |
Fred in Pa
Posted: 16 Oct 2020 at 8:48pm |
17 cord's in there now , last year I used 14 to heat all winter .was a mild winter .
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35692 |
Posted: 17 Oct 2020 at 8:49am |
STILL wishing I had set one up here, but kept running out of time and cash to get it set up, at least with ground source the expense is lower than conventional heat sources.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 17 Oct 2020 at 8:42pm |
Fire wood equals work. Ruined many Sat**days. Not for me.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12422 |
Posted: 17 Oct 2020 at 8:54pm |
Might get mine going tomorrow. Ugh....
Fred in Pa
Posted: 18 Oct 2020 at 7:51am |
With logs hauled here n then using the correct splitter ,takes !/2 the work out of it . Nephew bought one of these splitters that I trade out my dump trailer for using splitter Was his idea so I agreed . Split everything right aside wood shed .NO picking off the ground after split . |
Tbone95
Posted: 18 Oct 2020 at 9:54am |
What exactly is that Fred? So there’s like a table after the wedge for the split wood, but what’s the black doohickey?
Fred in Pa
Posted: 18 Oct 2020 at 10:49am |
Hyd. adjustable wedge Makes it a 4 way split .or he has a 6 and 8 way wedge .Or just remove wedge for single split .
![]() Edited by Fred in Pa - 18 Oct 2020 at 10:50am |
Tbone95
Posted: 18 Oct 2020 at 12:07pm |
Well, that’s cool, but not that black thing! The expanded metal cage type thing. And what brand?
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 18 Oct 2020 at 3:43pm |
Any of your neighbors complain about the stench of the smoke when it's damper door has it in "smolder mode" ?
Fred in Pa
Posted: 18 Oct 2020 at 5:30pm |
Freeguy ,NO !!! been 11 years burning it . Doing the day I only feed it what it needs as my business is right here .I only burn seasoned hard wood n you can see it says DRY. Its like any thing else once u learn the system it works .The guy above me that lights a shop stove in the evening and the dum@$$ burns green and wet wood has a issue with the guy on the south side of him .
Also having the stack at right height helps Edited by Fred in Pa - 18 Oct 2020 at 5:35pm |
Fred in Pa
Posted: 19 Oct 2020 at 6:34am |
Tbone 95 ,That is lift for big wood its just not down on ground in picture .
Tbone95
Posted: 19 Oct 2020 at 9:04am |
Kinda thought so. So, what brand is it, or did you modify it by adding the catch table on to it? Still using the Manuel Armstrong splitter here. Ain't as much fun as it once was. |
FREEDGUY
Posted: 19 Oct 2020 at 6:01pm |
Thanks for the reply, apparently 98% of the guys burning these "here" are burning green wood
. And it stinks worse than chicken s^*t ![]() |
DMiller
Posted: 19 Oct 2020 at 6:34pm |
When was cutting firewood, first year cuts were stored on other farm for a full winter and summer, seasoned. Then brought out and used or sold. The current conditions I have is seven larger walnut trees we had taken down as 1, TOO close to power lines then 2, had gotten to a size would become useless in a few years for logging and 3, were a few on drainage creek bank root mass washing out. One was already beginning to hollow out at stump and had to be trimmed to solid to sell.
Have maybe 5-6 Cords of Limb wood I need to hack down to firewood size and store up to dry out then can sell next season.
