1963 D grader engine |
Max-AC
Topic: 1963 D grader enginePosted: 14 Oct 2020 at 9:13am |
Hi there, i am wondering if i have the OEM engine in my grader...number stamped being carburator on the block says 17-32992-M...my grader is a 1963 square tube...
On the oil filter side there is an gas pump...I ve been told on industrial machine that they used gas pump... I think the engine would be the same as D17? Thanks. Max |
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 14 Oct 2020 at 11:05am |
The D I have is the old round frame one -----not sure about what the newer ones have for engines.
DrAllis
Posted: 14 Oct 2020 at 1:27pm |
The older model "D's" would have had a WD or WD45 engine. By the late 1950's they went to the D-17 engine, which is reflected by your serial number 17- xxxxxx.
