Checking compression on a deisel |
Post Reply ![]() |
ksbowman ![]() Silver Level ![]() Joined: 19 Mar 2013 Location: Paola, Ks Points: 228 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Oct 2020 at 9:21pm |
Hate to post this but, I want some direction. Let me say I've done nearly all my own mechanic work my whole life. It's always been on gas engines though. I've overhauled several car motors and balance and blueprinted a couple so, I'm not a rookie. I have a 170D and I need to run a compression test to track down a problem. Do I need to fabricate or buy an adapter plate to bolt on with an injector jig for checking the compression? Or is there an easier way? Any help explaining to this 70 yo would be greatly appreciated.
Edited by ksbowman - 11 Oct 2020 at 9:33pm |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21833 |
Injectors have to be removed and find (or make) an adapter to go in place of the injector body and connect it to a compression tester with a 600 psi gauge.
Thanks Doctor. That's what I assumed. If I could get one where would be the best place to look? Maybe a retiring mechanic I bet. Probably an elusive critter to find. Also Doc, Do Lancaster Balancers go bad often? Have you ever had one that had problems?
Edited by ksbowman - 11 Oct 2020 at 9:40pm |
Never had one of those balancers go bad, but I never had many Perkins diesels either. Most of my units were larger in diesel form. An old injector assembly with the guts removed and the nozzle tip sac ground off is a test adapter if you can get it to connect to your gauge.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54040 |
Does a 170 have individual glow plugs? If so, there are diesel compression gauges that go in through the GP hole...
![]() Edited by DiyDave - 12 Oct 2020 at 4:28am |
Those Perkins engines to not.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5094 |
Harbor freight has nice low cost diesel compression testers, but get the bigger set for this perkins.
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
I have a Star Products gauge from the Snap On Industrial catalog. Comparable quality to Snap On without the full Snap On price.
It depends on the engine as to whether they test through a glow plug or injector hole, but in this case it's through the injector hole as the Dr says.
wide ![]() Silver Level ![]() Joined: 29 Dec 2018 Location: north iowa Points: 169 |
On the VW diesels I work on
turning the engine over by hand gives me a good idea what the compression is. I don't have to worry about the change in volume due to the injectors or glow plugs being removed or volume of the injector tester being added to the volume of the cylinders. That said, I'm sure it's easier to turn a 1.6 or 1.9 diesel by hand than it is a AC 170 diesel. |
Post Reply ![]() |
