R-50 engine oil leak
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: R-50 engine oil leak
    Posted: 11 Oct 2020 at 2:26pm
Buddy recently bought a R-50 & went over it fixing a few things and thoughly kleening the engine, long story short (he drove it 60 miles home with out any problems) went to thrash beans today it started to leak engine oil and blowing on the turbo & manifold got his attention quickly. Asked me to look at it and I thought it would be a firing ring. Oil is running out of that area (#4 right behind turbo) but I don't think its the ring thats leaking because the engine run & sound great and no skip to the starter when cranking with fuel shut off. Would / could it be a push rod seal leaking? He did power wash both sides of the engine. Thanks Dave
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 2:50pm
Hmm wouldn't be one of the turbo oil lines leaking would it?
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 5:00pm
Push rod tube leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 5:53pm
Noy famailar with that engine ; but how would that show on the outside of the engine ? Arent they under the valve cover?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 6:34pm
Push rod tube at the bottom, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 6:46pm
Guys the oil is coming out rite were the fire ring is located thats why I,m thinking it mite be leaking at the top of the tube. Thanks Dave
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 7:45pm
There is an metal / cloth covered rubber oil line that goes to the blower fan clutch...have seen pin holes in the cloth covered line .... but probably a push rod tube seal - on a cold engine we open the cover to the fan and install a fabbed cardboard air diverter to keep oil from being blown by the blower -  helps locate leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 8:21pm
Are you sure it is oil, not diesel fuel? The injectors are famous for leaking where tip fits to body.        MACK
