Dual loader leaks on AC190
Jamz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamz Quote  Post ReplyReply Direct Link To This Post Topic: Dual loader leaks on AC190
    Posted: 07 Oct 2020 at 12:30pm
I mounted a Dual 320 loader on my AC 190 and it works great !  I was hoping I could find some help here regarding correct installation of the 13163 seal kits in the DUAL 320 bucket cylinders....I installed them per the only video I could find (You Tube Ty's Projects) and the exploded view of the cylinder and kit  per Messick's Woods Dual diagram 700. I still have steady drip leaking at the shaft ends...it appears to be coming out at the outer gland/nut threads and not at the shaft and sweeper ring. I know it's not an AC product but it's really hard to find detailed information on these Dual cylinder assemblies.
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2020 at 12:26pm
If I remember correctly when I did mine you possibly nicked a seal when installing back toghter its easy to do on those type cylinders or your ram has a defect in it
Phil
Jamz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 5:52am
Thanks, Phil
The rams are pretty beat up
