CA at Mile Branch Grange
Jack C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack C Quote  Post ReplyReply Direct Link To This Post Topic: CA at Mile Branch Grange
    Posted: 06 Oct 2020 at 7:26am
. Another great year for my Paul Barnsley built CA. We were so fortunate that our local track Mile Branch Grange , Sebring OH canceled only 2 pulls because of Covid , started back up in May and ran the rest of the season. We were pleasantly invaded by pullers from other states and local folks we had never seen. Biggest night was 363 hooks. I was never beat in 2750 or 3000. I’m very competitive in the 3250, probably won the track championship. There’s a WC that beats me now and then and it’s so fun to beat Farmal H’s and 230. Barnsley is the wizard of H.P. in the world of CA’s!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 8:50am
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 9:35am
What size rears you have on there?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 10:49am
They are 14.9X24 old style 45 degree tires that were road worn and I trimmed up the tops a bit.  They are a great match for the power that tractor has in 2nd gear for the light class.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 11:08am
I had thought about using 26's from a D15 but they are a wee bit expensive
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 6:44pm
That guy in the shack looks all pis.ed off, !
Edited by DougG - 06 Oct 2020 at 6:55pm
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 6:53pm
Dose not look like a CA engine
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack C Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2020 at 10:57am
Its a Div 4 or Class B at the tracks she pulls. Meets every rule stipulation of those particular class’s.
Edited by Jack C - 26 Oct 2020 at 11:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack C Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2020 at 11:04am
Edited by Jack C - 26 Oct 2020 at 11:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2020 at 1:28pm
I like it! Thanks for sharing and congratulations! Great looking tractor too!
Justin Vandy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin Vandy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 8:52am
Jack did Paul build you an engine? I am going to put a series II D15 engine in a CA to pull. Do you know what kind of power you make?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 3:34pm
A G-160 engine in fine tune, placed in a D-15 series 2 will make 46 HP at the PTO @ 2,000 RPM. Install that engine (as-is) in a B-C-CA chassis and I'd expect it to make at least 50 HP because you don't have a hydraulic pump or power steering pump to operate. A slightly higher octane fuel and advance the ignition timing no more than 5 degrees MIGHT pick you up a couple more HP. More RPM's would work good with this change as well. A larger carb venturi or even a larger carb will help add to the performance in the higher RPM range, and more compression like LPG pistons at 9.35 to 1 keeps adding power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin Vandy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 8:14am
This engine with have a 175 venturi. Higher compression would be nice. Is there anyway to achieve this other than LP pistons/custom pistons?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 12:08pm
Or longer connecting rods or pull the sleeves and deck the block a bunch and recut counterbores for the sleeves. It all costs $$$$$$$
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin Vandy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 2:02pm
I will do LP pistons....if I can find them.
This page was generated in 0.126 seconds.
