D19 gas motor to D17 diesel
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: D19 gas motor to D17 diesel
    Posted: 04 Oct 2020 at 8:22pm
Is it a simple job to put a D19 gas into a series 4 that had a bad motor. Sorry if its been asked before. Old guy has a D19 with bad rear end or tranny he doesn't know which. Good motor. Will it bolt into his D17? They are both complete units. D17 tossed a rod thru the block got into the water jacket. I get to look at it next week if he feels good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2020 at 9:05pm
It has been done, but the sheet metal won't fit, IIRR.  I don't envy you in this job...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 10:07am
Ok, probably pass on it. Thanks
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 1:51am
 Hey Tom,,,where is your adventurous spirit,,,? You do have a cuttin torch and a welder don't you,,,? Just think how much your neighbor will love you for bailing him out,,,,,,,,Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 9:47pm
Your title says 17 diesel...of so I don't see the challenge. Gasser would be different story.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 10:41pm
Wondering about it. I know my Diesel 17 was longer than the gas units. Was hoping it would be a simple bolt up. The D19 tin is good, rad is good. Could all tin be switched,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 11:44am
I'm thinking direct bolt in. May have to use clutch and flywheel from 17 but it should bolt to crank ok. PM the Dr. He will know. The engines are same physical dementions.
19 is wider I think so tin will not swap.
Edited by SteveM C/IL - 07 Oct 2020 at 11:46am
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2020 at 1:44pm
I repowered a wc with a 262 gas 6 cyl needs little to be considered done will be an awesome puller or tractor rider for sale due to health reasons send pm for more info
Edited by Gary in da UP - 10 Oct 2020 at 9:03am
This page was generated in 0.250 seconds.
