8070 2wd: Weak/No steering below 1500 RPM
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Topic: 8070 2wd: Weak/No steering below 1500 RPM
    Posted: 02 Oct 2020 at 10:53pm
Hey all,
Looking to buy a 8070 2wd Allis that seems to run and drive good... as long as you are above 1500 RPM. Below that it will not steer.
What is the worst case scenario?
Best case scenario?
The price is under 10K by a decent margin, hence the interest. :)
Its a powershiftif that affects the diagnosis.
Any info appreciated,
Thanks!
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 6:54am
My guess is flow divider is sticking or someone left orffic out.          MACK
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 8:09am
Left hand differential filter and screen would be an easy check and fix if there was something wrong. The gear pump for the steering would probably be the most expensive, although it's not that hard to replace. Always be sure that the front end is not binding in the spindles.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 8:40am
Safest answer is to forward the contact info to me. Won’t cost you as much
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 9:08am
Gear pump is in the main pump stack, correct? If its same as 7000 series shouldnt be terrible to find a used one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 8:51pm
It may be hard to find a good one.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 10:05pm
Th gear pump is in the pump stack as you call it. You have to remove the piston pump first and then take out  the gear pump with the gerotor pump attached. Once you have the gerotor section removed , then you can disassemble the gear pump. The 7000 series pumps would work although there have been improvements to them over the years ,so a later model would be best. Like Mack says, getting a good one is a bit of a crap shoot. If I get one from salvage, I always take it apart before I leave to make sure that it's better than what I have. 8000 series pumps for me have been pretty trouble free for me.  I would try and be sure that other areas are problem free before I suspected the pump.
Edited by Lynn Marshall - 05 Oct 2020 at 10:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 5:56am
Good hydraulic shop should be able to rebuild it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 6:33am
I don't care how "good" the hydraulic shop is....if they can't get the parts to repair it, it remains junk.  That dual pump is an OEM spec'd pump that fits nothing else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 7:41am
I know of two that will machine components
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 8:31am
I had a pump for the 540 wheel loader, which is proprietory to AC, done by Precision in OKC. Price was reasonable.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 7:02pm
still looking at this machine. Since the last post owner has changed differential filters with no change . Steers a little worse when hot.
Also, sometimes when remote is actuated nothing happens. Go back to hold then try again and it works fine..
Any thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:48pm
Tell me where it is. I'll buy it and get it fixed. Then, maybe I can sell it to you >> Sounds like a plan to me...
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 1:50pm
So you guys are saying for 8400, even with steering issues, I need to have bought it yesterday? :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 5:59pm
If you don’t bite on it give me contact info I might.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 10:19pm
Well, right or wrong its mine... lol
Now I definitely need to figure out the issue. :)
As long as the filters were clean with no metal, any harm in running it as-is doing some simple tillage work for the rest of the year?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 6:43am
That pump not only provides oil for steering, the excess volume is used to LUBRICATE the driveline. Get it fixed. Not telling you twice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 8:42pm
Agree with the Dr, if that range transmission shaft don't get oil, and a gear welds it's self to shaft, things get ugly.             MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2022 at 4:42pm
Hey guys,
I'm finally opening Pandoras box here, Tractor has sat since I bought it, me fearing the worst about potential damage.
Pulled the cap off and Mack was right, no orfice. I assume that is quite important? :)
According to the Agco parts book site, I am missing both #34 PN 70265406 (orfice) and #35 PN 70269666 washer both go on either end of the spring. how important is that washer?
I assume the orfice is the same diameter as the spring and fits inside the spool?
Spring looks good. cap has two shims in it.
Since we might be dealing with a sloppy mechanic from years ago, I better ask, is the long end of the spool supposed to go down or up? Currently long end down.
As far as the spool, there is zero roughness, feels smooth as glass. it did want to fight coming out though, I had to hook a center hole with an o-ring pick and pull. I think what fought was there was a few chunks of hard plastic wedged in 2 of the 4 holes. any ideas what the plastic might be?
Once the spool is in there, you can turn it with a finger. Do I need to sand it, or is it fine?
Also, the only time i drove it since buying it was 500 feet from where it was unloaded to where I am working on it, and it did sound like a pump was straining a little, is that from the missing orfice? Regardless I think I better drop out the left filter to see what everything looks like.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2022 at 8:16pm
This picture shows the parts involved and there order. Long end of spool is down and the orifice disc goes inside of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2022 at 9:17pm
Thanks for the pics Lynn, very helpful!
So just to confirm, the 70269666 Washer is identical in every dimension to 70265391 Shim, except for thickness? If yes, then you have Qty 1) 70269666 Washer and Qty 2) 70265391 shims in your pic, correct?
What would be the reasoning to add an extra? what about taking it away entirely?
My 8070 has 2 thin shims, the 7040 that donated the orfice has two thick and 5 thin under the cap. I doubt either is correct.
The 7020 I checked had 2 thick 1 thin, the 7050 has 2 thick 2 thin.
Would it be best to default to the 1 thick 2 thin and see how it operates?
Thanks for the help!
Edited by GM Guy - 14 Jun 2022 at 9:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2022 at 7:58am
I believe that the picture is from a 7020. The thick washer is the same diameter as the shims. It had two shims and one thick washer. That's what I would try and see how it steers.
