grain tank size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Topic: grain tank size?
    Posted: 01 Oct 2020 at 11:18pm
ona STS?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 6:55am
BIG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 6:56am
Well, which STS, there are more than 1 model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 9:29am
220 - 300
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 9:40am
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 8:04pm
Most of them here have after market extensions added too.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 6:16am
The one I chase around holds around 500 bu with the extensions added
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 6:21pm
Now I'm a little curious as to why you asked this?? Can I "assume" that you've rented out on "shares" and have been watching the UNLOADS and doing the "math" in your head as far as your "cut" ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 10:10pm
well...i was watching a neighbor field being harvested. it took 2 rounds to get a tank almost full with the extensions on it. could see the hump of the grain inside. he'd unload in the trucks at the end of the field. the last round he made he never unloaded into the trucks, he went home with the combine with how ever much was in the grain tank. this was a soybean field.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2020 at 5:11pm
We run a 700 bu cart and it will not hold two full tanks from a 9770 with bin extension. Guessing 375-400 bu there. At our 56 lbs avg. test weight an extra 21,000-22,400 lbs on board. We never road with grain in tank.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2020 at 8:55pm
Those be some pretty good beans if he was pushing a 12ft. header. WinkLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 1:16am
i'll hafta get the # of the combine when he goes past the place again, he has more ground down the road he rents. sure is a chitty way to treat a good landlord.
This page was generated in 0.836 seconds.
