Wd 45 lighting safety lighting?
Catalinacrasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catalinacrasher Quote  Post ReplyReply Direct Link To This Post Topic: Wd 45 lighting safety lighting?
    Posted: 01 Oct 2020 at 12:41am
About to finally put this thing to use, but the lighting concerns me as far as getting it on the road, I fee lkj pretty confident with the headlights I added tonight, the stock headlights pretty much just light up the side of the tractor, so at least I'm pretty visable on the sides and front, I have the stock taillight on the left fender, I have another stock taillight on a parts tractor to mount on the right fender, and a smv sign, but I think the rear needs to be a LOT more visable, any ideas? Or pictures of what you guys have come up with? This is honestly a huge thing for me, my gma was killed 3 years ago because the vehicle she was in hit a poorly lit tractor, so for my safety and everyone else on the road, I want this thing to be impossible to not see
I would rather be judged by 12 than carried by 6
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catalinacrasher Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 12:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catalinacrasher Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 12:50am
Thought about adding rock lights, would light the road underneath me and make my profile stick out, and make it easier to see underneath while in the field to avoid obstacles, look cool as hell too
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 7:52am
Why not put a let of "Lolipops" on the rear of the Tractor wired to a flasher? A couple 90 degree brackets off the back of the Tractor with the Lolipop Warning lights mounted to them will give anyone coming up behind you a heads up way before they get to you. The Lolipops I'm referring to are made by a few different mfr's like Grote, Signal Stat, Trucklite etc. The lens on one side is Amber and on the other side Red.  Wire a flasher to em' so they flash, and yer' good ta' go! Safety first!  We sell em', but you can find them in most Auto Parts stores or Tractor supply houses.... HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catalinacrasher Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 9:27am
I will definitely look into them, thank you, I know the lights your referring to, where might I get a flasher? Or just wire it into a turn signal relay?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 10:52am
If you intend on doing night road work I would put a yellow strobe light like the new tractors have on a pole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catalinacrasher Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 11:40am
Thanks guys I will sure look into both suggestions, I'll have to look into the DOT regulations for the legal mounting locations
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 11:45am
Strobe is a good idea.
I was thinking a set of magnetic tow tow lights. I use them on wagons. On the 7040, the P.O. wired in flasher unit to a pigtail for tail and hazard lights
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 11:02pm
I added a pair of amber flashing lights for when I'm on the road on my D17.
