hydraulics
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: hydraulics
    Posted: 30 Sep 2020 at 12:42pm
I'm looking for someone that knows hydraulic controls.
I bought a towable back-hoe.
It has 4 control handles/levers.
 Left to Right
   Boom Swing
   Boom Up-Down
   Arm In-Out
   Bucket roll In-Out
Is there something that can be added to slow the swing?
 Also when I push the boom up it drops some before it goes up. Is this a defect or is there a simple adjustment to fix this.
Thanks,
Dusty
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2020 at 1:17pm
Dusty, check out "color flow valve". But they're pricey. In any case, you need a restriction in the line, adjustable is nice. There are fixed-orifice flow restrictors available too. You'd have to experiment to see what size you need. But it's basically just a coupling that screws in between your hose and the cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2020 at 5:58pm
Surpluscenter.com has adjustable flow restrictors, about $10. You might need 2, if your machine uses a ram(s) instead of a clock motor, to rotate the arm.
What machine are you working on?Wink
Edited by DiyDave - 30 Sep 2020 at 5:58pm
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2020 at 8:58pm
There are several different styles available, and obviously different sizes, fittings, flow rates etc. Look on ebay or surpluscenter or Baum hydraulics or your local place for a "hydraulic flow control valve" I personally like the kind with a lever to one side better than the needle valve type, but that varies by application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2020 at 1:41am
if you bought it used your control levers and boxes might have alot of wear, do your levers wiggle without the hyd's moving anything? sometimes it's just a pin on the bottom of the levers that gets wore. not saying you don't need a restrictor, but i'll bet your controls are wore alot. also try to work them with the engine slowed up a bit, you ussually don't have to run the engine full throttle unless you are constantly moving the arm.
This page was generated in 0.242 seconds.
