WD45 Carburetor
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Carburetor
    Posted: 27 Sep 2020 at 3:11pm
Hey guys haven't been on in awhile. I had the carb on my WD45 professionally rebuilt a few months back. Some of y'all may remember this engine was completely overhauled a couple years ago. Ever since the overhaul choke needed to be on a little to run smooth under a load. After having carb rebuilt it still runs the same. I have power valve all the way open and it doesn't black smoke any and needs choke under a load. I spent alot of money replacing things that made no difference and had very little run time on them. Cap, rotor, wires, coil, electronic ignition module. Checked for good flow from tank. Adjusted valves, checked timing with a light. Still needs choke slightly on to run good under load. I need to find another carb to try I guess and see what happens. Also checked for leaks at manifold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 3:41pm
Sounds like the main jet in the bottom of the bowl needs to be drilled out .002" so you can then overfuel it with the adjustable main jet and then dial it back down where you want it.  Is the engine 1/8" overbore?? maybe requiring a bit more fuel ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 4:48pm
I was wondering about that but haven't went through with it yet. NOS D17 7.25:1 pistons, D17 governor spring.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 7:10pm
Definitely need main jet drilled out. I rebuilt my WD with higher compression and it likes about 50% ethanol, had to drill out the main jet a couple sizes just to get in the ballpark. Get a set of small numbered drill bits and a pin vise and go up one size at a time until you can run with the load needle about halfway in, fine tune from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 7:15pm
Thanks for the help guys. I'll pick up a set of numbered drill bits this week sometime.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 7:51am
I like to participate on tractor caravans with my D-10 series III.
After having the valves ground, it would start out running fine in the morning, and then not run right the rest of the day. And have to be trailered for the rest of the day.
A couple weeks later I got to look into it and found that the float in the carb was set too shallow.
Starting out in the morning when it was cool it worked fine. But as the day got hot the gas expanded so there were fewer BTU's in the amount of gas in the carb. I adjusting the float so the carb held more gas, and it runs just fine now.
 I would think that it would be difficult to intentionally set a carb that way.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2020 at 1:43pm
Sorry guys I forgot to come back and tell you what happened. Drilled the jet out a couple sizes. Runs great now. Took it to plow day this weekend and it ran great.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2020 at 9:35pm
Great to hear that your issue is no more - and thanks for coming back to let us know what happened!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 7:50am
I have never drilled out a carb. Thanks for the info, and glad it is working better too. Lets see the plowing pictures!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 10:14am
I had the same issue with my WD45 engine after Steve @ B&B rebuilt my carb.  Had to drill the main jet out a couple of hairs bigger and that solved the lean running issue.  My fault--as I had neglected to tell him I was running a Vinson manifold and some other engine mods!!  Runs just fine now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 12:28pm
My wife took a few pictures and some videos. I had a great time. It's good to have the tractor running the way it should be. One of these days I'll get it finished(maybe)!! :)
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 1:37pm
Looks good, lots of fun to plow with!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 1:40pm
Blake,
 Thanks for the nice plowing pictures! You have been doing some sheet metal work to the 45. It is weighted up nice too!
