message from door shock Tom
Message Reverse Sort Order
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Topic: message from door shock Tom
    Posted: 23 Sep 2020 at 5:16pm
  Nothing earth shattering.  I've had a few more calls then normal on the plastic ends on the shocks stripping the threads!   I've been kicking around if i should invest in stouter ends?   So i called my supplier an he says those ends aren't made to be replaced with stronger ones, as then instead of just the ends stripping, the shock will be ruined.   so from now on, I'm gonna put an extra end in every new shock kit.   If you buy from dealers, they should already have these ends on hand.   I don't charge them for the extra ends, so if they have a nominal fee, it'll be for the handling!   The thing that brought this to a head was the post office hitting me at least 3.90 to ship a 'shock end' that i give away for nothing.  This extra 'shock end' will allow you the safety of having an extra on hand!  No raise in price!!!!   I've made up 30 kits for the winter as we have moved off the farm and won't set up a shop until next spring after we return from the yuma arizona area!    The jan sale will happen just like it always has, but when i run out, that'll be it until late april!
  tom scheffert---402-641-1148 with any questions BUT like normal with all the telemarketers around i ask if you can 'text' first.   If you can't, no problem, but sometimes my zappers kicks new numbers over to the spam side!
Edited by tomNE - 23 Sep 2020 at 5:18pm
This page was generated in 0.172 seconds.
