1961 GAS D15 ser.1 Water pump
KYrod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KYrod Quote  Post ReplyReply Direct Link To This Post Topic: 1961 GAS D15 ser.1 Water pump
    Posted: 23 Sep 2020 at 1:31pm
Two bolts and a stud hold this water pump on.
IS THE STUD THREADED SO THAT IT CAN BE REMOVED FROM THE ENGINE BLOCK?  It's difficult to tell by looking.
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 2:35pm
My tractor was a D14, but that stud was threaded on mine. If series 1 D15, probably same engine and set up as my D14.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 4:16pm
yes the stud should be threaded. May be loctited into place if it goes into the water jacket
Post Options Post Options   Thanks (0) Thanks(0)   Quote KYrod Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 4:18pm
I ended up just retapping the stud and I think it will hold.
This page was generated in 1.303 seconds.
