Fiat Allis 745C with Volvo engine
Grelle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grelle Quote  Post ReplyReply Direct Link To This Post Topic: Fiat Allis 745C with Volvo engine
    Posted: 22 Sep 2020 at 6:48pm
I have A fiat hallas 745C wheel loader It has a Volvo Engine with a blown head gasket cannot find Engine Numbers .Which Volvo engine will fit this wheel loader
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 10:43pm
Wow... that is tricky as there are likely a number of Volvo Diesel engines that fit having SAE bell housing design. If you have removed the head you might find some numbers on the gasket itself. If the head is off you can measure bore and stroke and do the math for engine displacement. Once you know in cubic inch and even better in liter displacement, as that is how Volvo identifies them, you have something to go by. If local Volvo dealers can't seem to help, you may have to contact Volvo in Sweden for more comprehensive information at that point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grelle Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 8:55am
This Engine has six separate heads turbo sets above engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 9:25am
model and serial number are suppose to be on a tag on the valve cover...
