WD45 Clutch Bearing Assembly Correct?
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Clutch Bearing Assembly Correct?
    Posted: 30 Aug 2010 at 9:57pm
Just want to make sure I installed the new clutch Bearing correctly that goes on the clutch shaft gear and fits between the rearend transmission and hand clutch assembly. When I bolted the two together the large snape ring is between the two housings and seems to leave a small cap at the top end when bolted together is this normal?
Jim
