HD4 6 way blade- joystick?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: HD4 6 way blade- joystick?
    Posted: 21 Sep 2020 at 10:34pm
Is it possible to plumb a joystick control for 6 way blade on an HD4? How hard to do? Thanks Tracy
Edited by Tracy Martin TN - 21 Sep 2020 at 11:14pm
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 11:05pm
i WOULD THINK THE KEY TO IT IS IN THE JOY STICK VALVE . AND GETTING HOSES PLUMBED CORRECTLY  jUST MY THOUGHTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 11:16pm
Randal, I hit the wrong key. I meant an HD4 but should be similar. I know it would make operating a lot easier.  I figured someone has tried or done it.Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 2:54pm
do you want joystick electronic valves with true all electronic , pilot operated , or just a single stick wobble control
the valve itself would need changing for the proper volume , pressure and speed .
 I ran a Komatsu dozer with a all electronic joystick and without a lot of practice is seemed awkward to run over my FD5 6 way control .
 Then a 2 stick and or 4 stick backhoe gives one a different feel yet pilot control on excavator seems natural
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 3:46pm
I feel your pain
A joystick handle and its linkage could be adapted from another tractor
or mimic and make your own
Sure wish you would dive in and show us ...........
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 6:10pm
I don't see why it isn't doable. I will really look at it hard and determine if it is worth it. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 10:47am
seems my FD5 has 2 sticks  - left/right by moving the stick sideways / up/down by forward and back - but angle depth is set on corner of blades on separate stick actions of the 2 sticks .
 The Komatsu used push buttons to control single stick default to up/down , left/right , and button to change that motion into high or low corner of blade
This page was generated in 0.309 seconds.
