CASE IH 16 Row Corn Head
nella(Pa) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Topic: CASE IH 16 Row Corn Head
    Posted: 21 Sep 2020 at 6:19am
[TUBE]ZcvpCRiwX_I[/TUBE]
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 11:29am
Considering the fact that the largest unit I sold was the 66 two row All Crop I am AMAZED!!
Sixteen Rows. Almost too impossible for me to believe.
Even though it is Red I have no problem.  I am so impressed.  Also, how about how easily the header is removed for transportation.  Outstanding.  How about the tracks on the combine and tractor.  Great flotation.
Thank you so much for sharing.
How Impressive!!
Good Luck!
Bill Long
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 6:48pm
how much corn is on the ground when they get done
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 6:59pm
Don’t know how much but I would bet it’s a lot less than the green machines! The Axial Flow machine’s do a pretty good job. If you want to reap and sow at the same time go green.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 8:15pm
I am 54 years old and our small family farm got its recognition two years ago for being 100 years old. I remember as a small child my grandmother who was straight out of "old country" shelling corn in the summer kitchen by hand. Yes by hand. Times have surely changed but I would love to go back. Ryan
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 8:42pm
The HORST header wagons are built about 25 miles from me. A real company success story started on the farm.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 9:37pm
I have also picked corn by hand, tossed it into a steel wheeled wagon against a bank board. Scooped it into a corn crib. Couldn't do it today. I do like the Axel flows.
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 9:47pm
We still use older gravity wagons to move our grain to the bins. If I hooked both of our wagons behind our 7040 and started combining with that, I have a feeling I'd have both wagons full in about 10 minutes
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 8:37am
LOTS OF WORK is being done simultaneously! If that cornhead is 16rows x 30”, then 1acre of corn is being picked, threshed, cleaned, & elevated into combine’s grain tank ever 1089 linear row feet.
That means for a square 40 acre field, that’s easily 1 pass thru after headlands removed. So if that field is yielding 200, 250, or 300 bu/acre, it’s graintank is respectfully being filled, per EACH 1089’ pass!!! Multiple each pass’s yield by 33 passes, add the headlands yields & the 40 acres is completed.
If harvest speed is;
3mph ~ 3 hours/40 acres,
4mph ~ 2 hours/40 acres,
5mph ~ 1.6hrs/40 acres.
On a second glance at video, it may be 20” instead of 30” row spacing??
Edited by AC7060IL - 23 Sep 2020 at 8:40am
