Allis-Chalmers B
Countryboy92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Countryboy92 Quote  Post ReplyReply Direct Link To This Post Topic: Allis-Chalmers B
    Posted: 17 Sep 2020 at 10:13pm
just inherited an AC-B that has been sitting for approximately 2 years. Any advice before I load her up and carry her home?
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 11:34am
B what? B-10?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:42pm
If you talking about a B farm tractor... Change the motor oil and check the transmission / bevel gear oil for water... or just drain and refill.
Probably need to  run some gas thru the carburetor and see if it flows ok.. May need disassembled and cleaned out............  same with magnito.. pull a plug wire and check for spark... might need to pull the mag cap and clean the point face.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Countryboy92 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:43pm
All I know so far is its a 1949 Allis Chalmers B. Smaller garden tractor with a snap coupler set up. Comes with all kinds of sweeps and cultivators, a disk, double plow, planter with side dresser, and a mid mount scraper blade. Ive seen the tractor for a few split seconds in person and it has no decals
Post Options Post Options   Thanks (0) Thanks(0)   Quote Countryboy92 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:45pm
Steve, I had thought cleaning the carb, but not the mag. Good point!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:49pm
Countryboy... the problem is that AC made a "garden tractor" or lawn mower called a B10.... then their FARM DIVISION made a tractor called a "B"..... Yours should be a "small farm tractor"... has 24 inch rear wheels, 4 cylinder motor with a radiator, etc ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Countryboy92 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:50pm
Steve, yes that is correct
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:52pm
OK... you can post in the Garden Tractor  area if you want, just make sure you tell them you have a Farm Tractor... You will get more info and responses if you start posting in the FARM TRACTOR  area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Countryboy92 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:53pm
Sounds good. I appreciate the info!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:54pm
sounds like you are getting a lot of attachments... Post photos when you can... EVERYONE would be interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Countryboy92 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:58pm
Oh im gonna be posting pics and asking questions. Lol. I used to 3pt. And have to figure this snap set up out. I had a 57' Fordson Dexta and a 1980 AC-5040 a few years ago but had a heart surgery and ended up selling them both. So this is gonna be a get me out the house and piddle tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 9:47am
didnt think B had snapcoupler on them---never seen one. none of my 4 B's have any,---just regular drawbar,---need pictures of it.
This page was generated in 0.122 seconds.
