D17 and big round baler
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: D17 and big round baler
    Posted: 17 Sep 2020 at 9:31pm
I was just curious if any of you do any big round bales with your D17 tractor?
If so, what baler make and model?
4 ft wide bale or 5 ft wide bale?
Flat or hilly ground?
How many remotes for the hydraulics do you need?
Monitor on the baler?
Do you also bale cornstocks?
Thanks
Pastor Mike
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 4:09am
Back when I had cows, here, I baled with a D-12(III) pulled a Hesston 5530, did very well, everywhere, baling anything.  It needed one set of remotes, to open and close the rear door.  No monitor.  I'd say a 17 would pull a 540 or 550 Hesston, no problems!  Oh, and these Hesstons were re-badged by IH, and NI, and still in production, IIRR...Hug
victoryallis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 6:30am
Heck no!!!!!
Our baler is rated for 120 hp minimum.  I can make the 8030 snort with our 4x5.   Neighbor baled with a 160 40 years ago but it was a little 410 Deere baler.  The only D series that can make big bales is a D21.   When we bought the baler I thought the 6080 would be a match now I doubt it.
Post Options Post Options   Thanks (1) Thanks(1)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 6:36am
Oh we also need 3-4 remotes all but one double action.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 6:41am
Never tried a D 17, on ocassion used a 175 D on a 6x5 baler, fine on flat ground a bit light for hilly ground.
allisbred View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 7:12am
I have a Vermeer 504 silage I Baler that makes 4‘ wide x 5’ dia bales and use it on the 185’s mainly for the hydraulic PTO. I have ran it on the 175d without a struggle in dry hay. I think it requires 50hp min. It does not pull any load in dry hay until it is at full dia, meaning if there is a hp issue, you could simply cut off a little smaller. I prefer the monitor however, I also have a switch in case I would need to change tractors in hurry. This just means I have to watch it tie and turn the switch off and on. Most balers have the option for electric tie or hydraulic— I would stay away from the manual tie. If I only had a d17, I would use it, may not want to go down steep hills loaded would be my biggest issue. You need at a min ,is one dual outlet for pressure on the rear door. The other downside is the dust is close to you on the smaller tractors. I have baled anything that can be cut with this Baler.
Edited by allisbred - 18 Sep 2020 at 8:24am
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 7:18am
So, at a minimum, I think you'd want a D-17 with 16.9 x 28 rear tires with fluid, making the tractor weigh at least 5500 lbs. More weight the better for safety.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 7:20am
There's matches for a 17, and older New Holland 846 would be perfect, not the prettiest bales but they work , 4 by 5 weigh around 1000 lbs a bale
cpg View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 8:01am
Depending on the baler yes you could round bale with a D17. We have an older 5x5 Vermeer belt baler and an old New Holland 5x5 chain baler. Both just need one two way remote for the lift gate; have manual twine arms so no monitor or electrics to deal with. I'm sure some of the new big balers would be too much with hydraulics and or hp for a D17 but we have baled many acres running either baler with our 1947 Oliver 88 or a Long 560 so I'm sure a good D17 would be able to run them.
BillinAlberta View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 9:15am
   I have used a McKee 4 by 5 baler with hydraulic tie that required 2 sets of remotes on my Series 2 D17.A little under powered with the original engine but it got the job done .The tractor now has a combine engine and the extra power makes a difference.
     My Claas Rollant 62 makes a similar size bale but needs more horsepower so I usually run it with my DA7085.
Gregor View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 1:53pm
Once bailed for the neighbor using his baler and my tractor.  He had a Vermeer M baler and I had my White 105.  That baler pushed my white around pretty good.  Wouldn't want anything smaller for sure.  I usually bale with my 8030 and I have a Hesston 856A.  It is automatic and only needs PTO, no hydraulics.  Baler has a pump and own hydraulics that runs from the PTO. I don't think my D17 would handle my 856A very well plus I got rolling hills.
Ricky D View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ricky D Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 6:50pm
We run a Case 8430/Hesston 540 with 175D, 4 x 4 bales, handles it no effort, groans a bit w/full bale on a grade. Only tractor we've ever used on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 7:23pm
Gee wizzz, some of you guys got fancy balers !
DSeries4 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 9:20pm
Hydraulics would be the major issue unless yours is a series 4 D17.  Earlier models had the low volume/single acting hydraulics - not good for something with lots of double acting cylinders on it.
nickia View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 9:50pm
we used our series 4  d17 on a new idea 484  5' bale perfect size bale
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 10:58pm
Thanks everyone for the input. I have a Series 1 and was just dreaming. I think it sounds iffy at best.
Mike
Gary Burnett View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 5:52am
You can put a 2 way valve on a D17 Series I,I had a WD45 Diesel with a 262 gas in it and a double acting valve.Used it to bale with a NH 851,a little slow on the hydraulics but got the job done.Also to open and shut the baler gate no reason you couldn't mount a 12V electric over hydraulic unit on your D17 like lift gates and old wreckers used to use.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 6:20am
The installation of a single spool two-way valve to the left side of the seat wouldn't cost more than $200 for the valve and hoses. If the tractor has fluid in the tires, a 4 x 4 baler sounds like it would be fine. I think 800 to 1,000 lb bales would be as big as I'd want to go.
