185 / 500 loader lift capacity
185turbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Topic: 185 / 500 loader lift capacity
    Posted: 10 Sep 2020 at 8:23pm
What is the loader lift capacity for a 185 with a 500 loader on it? I got to unload a truck that may have 2000-3000 lb pallets. Im thinking 2000 lbs is ok but not sure about 3000 lbs
185 turbocharged w/ 500 loader , WD
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2020 at 9:03pm
I’m not sure but think 2000 is over the lift capacity.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 6:17am
Lifted an N6 engine out of the combine with a 185. I should say the guy I bought the engine from lifted it with his 185. IMO that was too much for a tractor like that. I don't remember what he had for a loader but that front end looked like it was going to fold up. He backed straight back out of the shed then I backed the pickup under the engine. I was waiting for a spindle to snap. An N6 engine must be around 1,700 lbs.
Wink
I am a Russian Bot
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 9:13am
According to my model 500 series manual;
Lifting Capacity at Full Height
D-17, D-17IV, D-19     2300
Carrying capacity @ 3 Ft. Height
D-17, D-17IV    3400
     D-19   3500
Breakaway Force
D-17, D-17IV, D-19   4000
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 11:42am
[QUOTE=Clay]According to my model 500 series manual;
D-17, D-17IV    3400
     D-19   3500
Breakaway Force
I have loaders on a 185 and 180 I'd cut those number in half.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 12:07pm
The load rating may be from the bucket pin area, not actually in the bucket itself.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 3:55pm
Clamp on forks move the pallet wt completly out in front of the bucket greatly reducing loadrating
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 3:59pm
Have a set of forks for my 500 on a 180, due to Hydraulic pump age and wear, small dia of cylinder barrels and Reliefs settings in the controls mine will ONLY raise 2000 pounds.  As far as front tires compressing is about all I will EVER put to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 5:21pm
There not rated for much matbe 2000, i picked up a cube of brick with my 6060 and what ever loader fits on it and bent the tip cylinders, they dont leak but have definet bends !
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 11:45pm
Meanolallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 9:06am
1981 brochure for 185 says: Lifting capacity to full height: 3400 lbs. Carrying cap. @ 3 ft. 3400 lbs. Max. Breakaway force: 4000 lbs. Max.
I think the full height value might be a typo since the other models (for 5040/5050/6060/6080) that carry ~3400 at 3 ft. are only rated to 1800-2000 at max height.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 10:42am
Maybe, or they figure a 4000 lb tractor SHOULDN'T be carrying 3400 lbs overhead for fear of upsetting it ?? Where the 9000 lb 180/185 might be harder to tip over. ??
