D15 Water pump |
Post Reply ![]() |
KYrod ![]() Bronze Level ![]() ![]() Joined: 07 Feb 2020 Location: Louisville KY Points: 72 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Sep 2020 at 5:09pm |
I recently got this tractor running and now find that it's leaking around the water pump. Is this likely to be a gasket failure or what?
Just drained new radiator and preparing to remove it....
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22054 |
Likely to be a gasket failure ?? Nope. The shaft seal is more likely the problem. Time for a reman water pump.
Any recommendations on a supplier???
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 3034 |
Got mine from Sandy lake . HTH
Post Reply ![]() |
