D10 Pto help
Chris View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Topic: D10 Pto help
    Posted: 08 Sep 2020 at 10:03pm
I have a series III with live pto.The pto seal leaking so I took plate off
To get to seal.The pto shaft moves up and down about 1\8" .What is going on here?What am I getting in to get fixed?
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 4:40am
Question:  This movement you mention, is it movement by hand, meaning with the engine off, can you move it that much?  or does it move that much, with the tractor running and PTO engaged?  Can you feel a surging, in the PTO lever, as you engage/disengage PTO?
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 5:51am
Movement by hand when off,if you hold the engagement lever all the way forward or back it tightens up.Is this normal
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 6:08am
Its a long shaft, with a short coupler, up front, so movement by hand is normal.  Spin the outboard bearing, see if it feels gritty, or unusual.  I wouldn't worry about it too much...Wink
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 9:21am
The pto shaft is 2 parts, the one that sticks out that you hook things to, is short. It goes into a damper housing, then there is a long shaft that goes from that damper housing to the fly wheel/engine crank.
That damper housing has 2 fiber, half moon like, parts. They were missing on my D-10, and I could not find any, new or used. Somewhere I fount one, needs two. I did find some martial to make them.
I would think that you better take the PTO cover housing off and check things out.
If you find that you need a pair of those, parts book calls them dampers, I can make you a pair.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 11:30am
Dusty, can you post a pic of dampner? I have seen one, but wondered if it were correct. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 12:19pm
Tracy, PM me your e-mail add. I'm not good at posting pictures on here.
Dusty
