2035 mag removal |
farmboycitygirl
Topic: 2035 mag removalPosted: 08 Sep 2020 at 6:52pm |
I need to remove the magneto from my 20/25 to get it repaired - anything special I need to do?
Edited by farmboycitygirl - 08 Sep 2020 at 6:53pm |
Pfouts Family Farm
Joined: 05 Dec 2018 Location: Hiram, Ohio Points: 177 |
Posted: 10 Sep 2020 at 10:11am |
Just remove the bolts from the base and don't turn anything. Pull the mag away from the shaft and collect the shaft couple when it drops out. Once you have the mag off of the tractor remove the cap and make note of the position (which cylinder is going to fire, or has just fired). When you put the mag back on, it can only go back on in one of 2 positions based on the coupler... the right one and 180 degrees off, just make sure it is in the same position as it was when you took it off and everything should be in time as long as you do not move the position of the engine while you have the mag off. Hope this helps
