Tractor cover for a D10 and others
justinhamlett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote justinhamlett Quote  Post ReplyReply Direct Link To This Post Topic: Tractor cover for a D10 and others
    Posted: 07 Sep 2020 at 6:04pm
What brand/type of tractor cover does everyone in  the community recommend? I have a D10 that I would like to keep safe from all the elements (sun/rain/etc). I also have a couple other tractors that are sitting out that would benefit from some protection, largest being a D19.
Thank you!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 8:21pm
I use a barn!  Far better than any cover - never seen any factory covers.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 8:46pm
X-2
Dusty
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 9:14pm
Any cover you use must be vented covering it with a tarp traps condensation and is much worse than letting it sit outside. I keep mine inside a tractor shed. Just an open end lean to on the side of the barn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 9:25pm
If you use a tarp, dont let it fit tight like mentioned above.. Take a 12 ft 2 x 4 and  have it attach to muffler stack and set on seat back.. Take a  tarp and stretch over the top and stake down at the corners so it looks like a tent and can breath under it... Dont lay it tight and box it up.......... making a semi permanent frame work with a tarp over it that you can drive under is another option.... a tent.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 10:50am
ShelterLogic Enclosure Kit for Super Max 20ft. x 10ft. Outdoor Canopy Tent — Fits Item# 55424, Model# 25875
if you cant afford a building. Northern-tool sells these. $110 20'x10'
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
