How much does a D-15 series II with a trip loaderw
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Topic: How much does a D-15 series II with a trip loaderw
    Posted: 29 Aug 2010 at 7:21pm
I would like to take my D-15 to some land I own 70miles away to get some work done.
I was wondering how much it weighs. No wheel weights but tires are loaded. I have a chevy silvarado 1/2 ton and a 16 ft. car hauler trailer.
barky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barky Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 8:07pm
Go for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 8:10pm
I have loaded rears on my 45 and have hauled it with the 7,000lbs. carhauler many times. As long as the trailer brakes work, you shouldn't have any problems.  Charlie
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 8:23pm
I haul my L 35 Loader Backhoe on a 7000# Hudson, brakes on both axles. The Tractor/loader backhoe weighs 6000#, so I am a tad over max. I pull with a 94 1/2 ton with 4.3 engine. Always careful to balance the trailer so it don't wag. I suspect if you add an implement you will be maxed also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 10:46pm
Does your half ton have the 5.3 in it?   If it does, I wouldn't think twice about doing it.   I used to have an 02 silverado with the 5.3 and with my equipment trailer, I pulled around my D15 which had a fully hydraulic loader on it, and other equipment as well.  It should handle it fine, but like the other stated, make sure you have good trailer brakes and a good trailer brake controller.
