D-15 oil pressure
DAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DAM Quote  Post ReplyReply Direct Link To This Post Topic: D-15 oil pressure
    Posted: 29 Aug 2010 at 6:18pm
 Does anyone know what I sould expect to have for oil pressure on a D-15 Series II with the 160 cu in engine?
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 5:38am
Mine runs on the "A" in normal.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 6:55am
30 to 32 psi at full throttle.
DAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DAM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 9:50am
Mine is running about 25 psig idling cold. After using the brush chopper for a while I noticed it was only about 5 psig. If I throttled it back down to idle, it went down to almost nothing.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 10:22am
Yea, I would be looking into that.  You might have a plugged tube/gauge so it might be wise to buy/barrow a test gauge and see if there is a difference in readings before doing anything else.  I don't know if that model still uses the bypass filter or switched to the full flow, but if it uses the bypass make sure the vertical tube thats in the filter base is still there and didn't come out with the last oil filter change.  Good luck
LannyMTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 12:43pm
Sounds like mine. It was overhauled before I got it, they didn't replace the cam bearings. It is a full flow filtration system. My solution is to use Rotella T 30 weight, and a quart of Lucas every oil change. I have used the tractor very hard this summer on the brush hog, reclaiming CRP land, and have had no problems. The engine uses no oil, and has great power. However, be forewarned , rods for that engine are about $200 the last,time I saw
something posted about them. Also when you have been working it hard, especially brush hogging, check your radiator screen often, and let it idle at 1/4 throttle for few minutes before pushing throttle completely up. HTH
Lanny
