912 does not charge
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: 912 does not charge
    Posted: 25 Aug 2020 at 5:55pm
The tractor is 100 miles away and would like to bring parts the next time I go there. I suspect rectifier. What type is used on this tractor? Where is is located?
DaveBsACs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveBsACs Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 8:20pm
should be a flat one on the engine shroud, 3 wires all in a row . if still original Kohler. Could be bad connection or wire. Get hold of plug and wiggle, watch gauge while running,have seen corrosion be the problem before.
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 9:06pm
Had the same problem with my 912. Turned out to be the ignition switch.
Albow44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albow44 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2020 at 5:26pm
I was having this same issue last spring on my 712 Shuttle. I changed the Rectifier and haven't had a problem since.
