Tie rod question
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Tie rod question
    Posted: 23 Aug 2020 at 6:53pm
What is the reasoning for B arched axle tie rods to have different threads, one is finer than the other, both are right hand?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 6:56pm
NRY
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 7:49pm
160+ views
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 8:06pm
No idea and all that would have been in design that could give a solid answer is dead. Most likely the reason for the silence.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 9:31pm
i never noticed a difference !  Allis didnt MAKE tie rod ends/ ball joints , they BOUGHT them, so what ever was available i guess.
you said they are both RIGHT hand threads ?  Never noticed that either... are you sure one of yours was not changed ?
Edited by steve(ill) - 25 Aug 2020 at 9:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 9:38pm
well, your right... says LEFT HAND, but its a right hand thread  18 thds per inch.... right side is 207725 and is 14 thrds.  ???
Edited by steve(ill) - 25 Aug 2020 at 9:42pm
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 9:49pm
This allows for a finer adjustment allowing the clamps to be on top.
If both had the same thread you would just be moving the tie rod
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 7:02am
What does "NRY" mean? No response yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 3:40pm
Tbone you get the gold star....
The one I first noticed this was a '39, I thought maybe someone had changed one of the ends, but I checked on the '49 it was the same.  The reason for noticing this is my grandson and I were pull starting it, I said hook it around the round rod (meaning the stabilizing rod), well he hooked on the tie rod,  when let the clutch out tie rod bent.  I should've not been to lazy to get off and look where it was hooked.  Thanks for the replies...Tim
