ISO A/C 172 Rotary Mower chain guards(Got Them)
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Topic: ISO A/C 172 Rotary Mower chain guards(Got Them)
    Posted: 20 Aug 2020 at 8:48am
Anybody have chain guards to fit an A/C 172 rotary cutter?
Edited by ac45dave - 13 Oct 2020 at 9:45am
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 7:51pm
Dave...If your good at the search thing, there was a discussion a long while back about that subject....I think I posted some manual info if that would give you a start....Dale
 ***  I looked back and see the pic date was Dec 20, 2018..  I think the consenus was, everyone on his own....This is one of the pic posted...I think !!!!
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 6:02am
Dave, I posted a source along with photo of these shields under your mower post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 8:36am
What's the part numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 11:04am
front support #538019 or 70538019...rear support #538015 or 70538015....chain #531067 or 70531067...front rod #538020....rear rod #538016...         Let me know what you have.Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2020 at 7:28pm
BTT
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 4:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 9:57am
I would fab it with a welder,torch,angle iron and flat metal. Weld links to bottom side. Can't imagine anyone ever pulling the rod and removing then replacing chains. My Woods doesn't throw enough out  to make it worth while...yours might?
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 2:20pm
I made my own years ago also...measured pictures in my operators book and scaled them to the mower...bought a blank piece of metal and measured it out for my blacksmith...he notched the chain holes and bent the angle...I made the rod and cut the chain links and drilled my own mounting holes after lining it up on the mower.
Matt Folkers
FOLKERS RESTORATION
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 6:32pm
On my 172 mower I installed a old AC baler belt, no more sticks,grass or any thing hitting me now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 3:03pm
.......Matt...Did you just notch or punch the actual chain size slots/holes?  Staying healthy??  Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 9:03pm
They were punched.  I'm staying healthy so far yes.
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 10:43pm
I was at the farm today and remembered to check. I have a 172 that has the front set of chains. If enough interest I would reproduce some like original. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 7:03am
Guys, thanks for all the replies.I'm still weighing my options on what to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 9:49am
Guys, thanks for the replies.I ended up having these made by Schmidt Machine Company in Upper Sandusky Ohio and they did a wonderful job on them.
