Allis Chalmers Standby Gennerators |
texasred
Joined: 29 Aug 2010 Location: South Texas Points: 3 |
Topic: Allis Chalmers Standby GenneratorsPosted: 29 Aug 2010 at 10:10am |
Hello all,
I am new here to the site and need some expertese on how old and when (years ) did Allis Chalmers produce skid mount generators? They must have sold a ton of them Sorry I dont have any nameplate data at this moment other than i am thinking about buying it for my farm where the power company wants $$$$$$ in the thousands (16K) to get power down to my farm. The generator is a 30KW it cranks and runs great and is dieselpower and it shows to have 1223 hours on the hour meter.What I am most concerned about the availability of general parts (oil filters, water pump etc......) to keep this thing in top shape. I already ahve run into this problem before as I purchased a 1977 50KW onan with a Ford Dorsett diesel and had to have a water pump which ended up costing me $495.00 because it was obsolete and the folks I got it from were the only ones whom had it in the world, with exchange of course. OUCH yes I did buy it by the way I guess a good way to look at it is at least it was available. The 30 KW Allis Chalmers is also a skid mount unit which has a built in tank and already on a trailer which is a plus. Please advise if anyone out there owns one or can pass on any info at all.
Thanks and God Bless
Gary in Texas
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 29 Aug 2010 at 10:34am |
a kilowatt is about 1.5 HP, so im guessing you motor is about 45 HP. Is it a 4 or 6 cylinder motor, does it have a tag ?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 29 Aug 2010 at 11:06am |
AC seemed to use parts that were easy to find as far as accessories to engines. Some items may be harder to find butthey are out there on someones shelve.
Minnpar web site might answer some questions on what is common items they can supply.
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 29 Aug 2010 at 11:23am |
A picture is worth a thousand words...Allis made many industrial generators using their 426 cu tractor engine from probably the late 60's to the early 80's...those are commonly seen for sale on e-Bay. Engine parts are readily available for those. If you can't post a pic, tell us more about it. How many cylinders is the engine? Six would match either the 426 or the 301. Turbocharged? Size of the block both length & height?...again look for an engine data plate on the side of the block...someone may have painted over it. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
kip in cny
Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
Posted: 29 Aug 2010 at 4:53pm |
Parts for the allis motor are easy to get. But if you have a true allis gen end they can be hard They used a swinging penugum voltage regulator that you hopes never breaks. I have never seen a 30kw allis gen-set. The size I normaly seen were 100 to 500kw. I would realy like to see a photo of this thing. The data card on the gen end should tell you who's end it is. If your lucky its a generac end they are easy to find parts for. The ford diesel they are not that hard to find parts for it may of been your dealer I have rebuilt 2 of them in the last 4 years. A few diffrent companys used allis motors on their gen-set like onan, generact, ITT, marathon If you cant do a photo tell us what color the gen was from the factory. kip
160 CA 920diesel 5020 HD-3
texasred
Posted: 29 Aug 2010 at 8:23pm |
Thanks to every one for the replies. I will get more info tomorrow and look for the data plates on the engine and generator end as well. I will figure out how to post a picture of the genset for those of you whom have never seen a 30 KW model.
Thanks again
Gary C.
texasred
Posted: 30 Aug 2010 at 10:34pm |
Gentlemen,
Here is all the info on the Allis Chamlers skid unit generator,
Engine data - Allis Chamlers D 262
Serial # 4-7451-99735
Generator data -
Serial # 365A68-5953N25
Type- BGKB
Leads--12
Phase- 3
PF-.86
Htz- 60
RPM- 1800
Volts- 208-240/416-480
Cont. Rating KW= 30
KVA-37.5
Insul Class = F
Reg. Model - CS-108-1
I cannot get the pictures to attach because of file size. %$##%^&**&^%^&*
You must be smarter than the program you are working with.
Gary in Texas
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 05 Sep 2010 at 11:52am |
Parts easily availavle for the motor but i cant say about the generator as i dont have a clue.
Gary in Texas
Joined: 11 Sep 2009 Location: Burkburnett, TX Points: 630 |
Posted: 05 Sep 2010 at 2:15pm |
south Texas?
