FL145 Loader Steering Pump prime |
dfrancis
Joined: 11 Aug 2020 Location: North Texas Points: 3 |
Topic: FL145 Loader Steering Pump primePosted: 11 Aug 2020 at 11:03am |
I replaced a Hydraulic line that went from the steering filter to top of the rear-end. The machine will not steer now. There is plenty of oil in the hydraulic reservoir. If I break the line loose coming out of the filter there is no flow. It splattered a little and then quit. Seems like the pump needs to be primed. Looking for any advice.
NomoreJohnDeere
Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
Posted: 11 Aug 2020 at 1:43pm |
did you do anything to "un prime" it?
if you take the filter out or the inlet to the filter loose do you have flow? |
HD3
dfrancis
Posted: 11 Aug 2020 at 1:54pm |
I took the filter off. There is no flow to the filter.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34307 |
Posted: 12 Aug 2020 at 7:16pm |
Can try adding 5-10 lbs REGULATED air pressure to the tank and at a little at a time to see if any suction leaks then start it to see if will pick prime back up.
